Results 1 to 11 of 11
    yugo45's Avatar
    Apr 2010
    Default Mercedes G Class
    Can anyone tell me is it possible to do direct with eeprom dash on Mercedes G-Class 2014-2015?
    Dash looks like this one:
    https://di-uploads-pod3.dealerinspir...-016-GOI-D.jpg
    If it is can someone share location of the Eeprom chip and how to get there ?
    Thanks In advance
    Mar 2010
    Hi.It is easy job to open dash and remove eprom.just remove dislay and U will find eeprom.
  3. The Following User Says Thank You to nikka For This Useful Post:
    yugo45 (21st March, 2019)
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by nikka View Post
    Hi, Does it Needles has to come out , or Display can come out along?
    Do you have any manual for this?
    Thank you
    kachimbi's Avatar
    Oct 2012
    No , its just in between the dials under the screen..
  6. The Following User Says Thank You to kachimbi For This Useful Post:
  7. #5
    yugo45's Avatar
    Apr 2010
    Ok I found it , it is very easy , Thanks for that.
    Eeprom is 95640.
    Can someone calculate Km for me , Original 19065km , I need 25250km. (Yes I need to go up about 6000km)
    Also does anyone know can I test to see Km on table , I see in diagram Pin 1 is Ground , Pin 4 is 12V but not see how to light up LCD?
    Thanks In advance .
  8. #6
    sony_2006's Avatar
    Mar 2010
    algeria
    Try the file if it is correct Thanks +Reputation
  9. The Following User Says Thank You to sony_2006 For This Useful Post:
    yugo45 (23rd March, 2019)
  10. #7
    yugo45's Avatar
    Apr 2010
    Anyone knows how to light up LCD on table , it is possible at all?
    Just want to make sure what Km display.
  11. #8
    diagtech2000's Avatar
    Jul 2013
    North of England
    probably needs can to wake up it would be easier to just plug in into car to check
    Please hit thanks if this helped you!
  12. The Following 2 Users Say Thank You to diagtech2000 For This Useful Post:
    kachimbi (25th March, 2019), khoums (26th March, 2019)
  13. #9
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by diagtech2000 View Post
    The problem is that If I plug in car and it is more km then I need then EZS will pick up this and will not be able to go back without Filters which I do not want to happen.
    Unless someone is 100% sure file in post #6 is 25250km?
  14. #10
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Quote Originally Posted by yugo45 View Post
    sony_2006 file has 25.216 kms on it.
    03 14 to DEC = 788
    788*32 = 25.216 kms
    Change 0314 to 0315
    Good Luck!
  15. The Following 3 Users Say Thank You to jomberykaso For This Useful Post:
    kachimbi (25th March, 2019), sagie (25th March, 2019), yugo45 (25th March, 2019)
  16. #11
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by jomberykaso View Post
    03 14 to DEC = 788
    788*32 = 25.216 kms
    Change 0314 to 0315
    Good Luck!
    Thank you all good.
    Also I just find out other way , use Tacho Soft W221 calculator and swap bytes form that calculation.
