Results 1 to 8 of 8
    Mar 2020
    Default Audi A4 B5 cluster swap VCDS: Channel 50 not available
    Hey there
    I am having an issue with a cluster swap on my Audi A4 B5 MY 2000.
    I was having issues with the original cluster (known problem of lights going on/off, needles going up/down...). I decided to buy a new cluster off ebay. I managed to pull the pins for both the old and new cluster with VAGTacho. I then tried to use VCDS to do the swap but when I try to put in the original Immo PIN into the replacement cluster through 21-Adaptation, I am getting an "Error Channel 50 not available" whch prevents me from completing the swap. FYI, the engine starts and runs fine with the original cluster but when the replacement cluster, the immobilizer light flashes.
    Would you know what I am doing wrong?
    Below the Autoscan of the original and replacement clusters. As well, the measuring blocks for the orginal+replacement clusters.
    Thanks for the help
    Error message:
    Adaptation Channel 050:
    Stored value
    ERROR:
    Channel 50
    Not
    Available
    Original cluster AUTOSCAN
    Sunday,29,March,2020,17:49:14:00007
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.0.2 (x64)
    Data version: 20180927 DS296.0
    VIN: XXXXXXXXXXXXXXXXX License Plate:
    Chassis Type: XX (8D - Audi A4/S4/RS4 B5 (1995 > 2002))
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    VIN: XXXXXXXXXXXXXXXXX Mileage: 226290km-140610miles
    Address 01: Engine Labels: 038-906-019-AJM.lbl
    Part No: 038 906 019 AN
    Component: 1,9l R4 EDC 0000SG 1301
    Coding: 00002
    Shop #: WSC 06435
    VCID: 63C5198DF155BF52A8-4B18
    1 Fault Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - Intermittent
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
    Part No: 3B0 614 111
    Component: ABS/ASR 5.3 FRONT D00
    Coding: 00012
    Shop #: WSC 06435
    VCID: 53A5C94DA1F54FD238-513C
    No fault code found.
    Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
    Part No: 8D0 820 043 N
    Component: A4 KLIMAAUTOMAT D58
    Coding: 00043
    Shop #: WSC 06435
    VCID: 2B55B1ADD905371250-25A4
    7 Faults Found:
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
    30-00 - Open or Short to Plus
    00603 - Footwell/defroster Flap Positioning Motor (V85)
    41-10 - Blocked or No Voltage - Intermittent
    01272 - Positioning Motor for Central Flap (V70)
    01274 - Air Flow Flap Positioning Motor (V71)
    01273 - Fresh Air Blower (V2)
    17-10 - Control Difference - Intermittent
    01206 - Signal for Duration of Ignition Off Time
    27-10 - Implausible Signal - Intermittent
    01582 - Signal for Coolant Temperature
    Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
    Part No: 8D0 959 655 J
    Component: Airbag Front+Seite 1001
    Coding: 00104
    Shop #: WSC 06435
    VCID: 3D718FF53771A9A2FE-5178
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
    Part No: 8D0 920 900 M
    Component: KOMBI+WEGFAHRS. M73 D51
    Coding: 00040
    Shop #: WSC 00000
    VCID: 2D51BFB5E71139224E-4B18
    XXXXXXXXXXXXXXXXX AUZ5Z0Y6074095
    10 Faults Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    00771 - Fuel Level Sensor (G)
    00667 - Ambient Temperature Signal
    00779 - Outside Air Temp Sensor (G17)
    01128 - Immobilizer Pickup Coil (D2)
    35-10 - - - Intermittent
    01177 - Engine Control Unit
    64-10 - Not Currently Testable - Intermittent
    01176 - Key
    00562 - Sensor for Oil Level/Temperature (G266)
    00668 - Supply Voltage Terminal 30
    53-10 - Supply Voltage Too Low - Intermittent
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    Address 35: Centr. Locks Labels:. 8D0-862-257.lbl
    Part No: 8D0 862 257 B
    Component: ZV-Pumpe, Funk D16
    Coding: 14913
    Shop #: WSC 06435
    VCID: 2C57B2B1DC0B302A59-4F02
    6 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    01389 - Tailgate Open Switch (F124)
    00991 - Interior Lights
    28-00 - Short to Plus
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    Address 56: Radio Labels: 8D0-035-1xx-56.lbl
    Part No: 4B0 035 186 E
    Component: Radio 0001
    Coding: 00201
    Shop #: WSC 06435
    VCID: 224B5C89AECFF65AE3-4B00
    1 Fault Found:
    End-------------------------(Elapsed Time: 04:18)--------------------------
    Original cluster measuring blocks:
    Address 17: Instruments (8D0 920 900 M)
    17:42:55 Group 022: Immobilizer I
    1 Engine Start permitted
    0 Engine (ECU) responds
    1 Key Status
    4 Number of adapted Keys
    17:42:55 Group 023: Immobilizer II
    1 Variable Code authorized
    0 Key Status (Transponder)
    1 Fixed Code authorized
    6.0 Immobilizer Status
    17:42:55 Group 024: Immobilizer III (Lock Time)
    0.0 Lock-Time Instrument Cluster
    0.0 Lock-Time Engine (ECU)
    0.0 Lock-Time Emergency Unlock
    0.0 Lock-Time Transponder
    Replacement cluster AUTOSCAN
    Sunday,29,March,2020,17:18:26:00007
    Coding: 00002
    Shop #: WSC 06435
    1 Fault Found:
    Coding: 00012
    Shop #: WSC 06435
    VCID: 53A5C94DA1F54FD238-515A
    1 Fault Found:
    01203 - Electrical Connection between ABS and Instrument Cluster
    31-10 - Open or Short to Ground - Intermittent
    Coding: 00043
    Shop #: WSC 06435
    VCID: 2B55B1ADD905371250-25AA
    7 Faults Found:
    Coding: 00104
    Shop #: WSC 06435
    1 Fault Found:
    Component: KOMBI+WEGFAHRS. M73 D56
    Coding: 00060
    Shop #: WSC 39527
    VCID: 2D51BFB5E71139224E-4B00
    XXXXXXXXXXXXXXXXX AUZ5Z0E0257036
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Coding: 14913
    Shop #: WSC 06435
    VCID: 2C57B2B1DC0B302A59-4F1E
    6 Faults Found:
    35-00 - -
    00955 - Key 1
    00956 - Key 2
    Coding: 00201
    Shop #: WSC 06435
    1 Fault Found:
    End-------------------------(Elapsed Time: 04:22)--------------------------
    Replacement cluster Measuring blocks:
    22:51:41 Group 022: Immobilizer I
    0 Engine Start permitted
    1 Engine (ECU) responds
    1 Key Status
    2 Number of adapted Keys
    22:51:41 Group 023: Immobilizer II
    0 Variable Code authorized
    0 Fixed Code authorized
    22:51:41 Group 024: Immobilizer III (Lock Time)
    brend's Avatar
    Oct 2015
    Same where
    All immo in here......https://www.digital-kaos.co.uk/forum...y.php/178-IMMO
    What about key's for new cluster?
    New cluster is same like ori?
    NB!!! Don't ask in PM old file password , Im not remember.
    Mar 2020
    Hey @brend
    The replacement cluster came without ignition keys, I will be using my original keys.
    I think the 2 clusters are the same. See below
    The original cluster part # is
    The replacement cluster part # is:
    brend's Avatar
    Oct 2015
    Same where
    And how you know like original immo chip not locked for programming?
    Quote Originally Posted by poolpo View Post
    Hey @brend
    Aug 2015
    Latvia
    Hi, first set coding 00040 from old cluster! Keys must bee adapted . New transponders must be used only if booth ECU ( cluster and engine) is changed.
    Mar 2020
    Quote Originally Posted by armi
    ,Hi, first set coding 00040 from old cluster! Keys must bee adapted . New transponders must be used only if booth ECU ( cluster and engine) is changed.
    Hey armi, thanks for your answer. A few follow ups questions:
    -Are you referring to soft coding # 00040 for the original cluster and soft coding # 00060 for the replacement cluster? What should I do with that?
    -I thought the key needs to be adapted after the PIN from the old cluster is moved to the new cluster via Adapatation and then channel 50. Isnt that correct?
    Thanks again
    Mar 2020
    Quote Originally Posted by brend View Post
    Not sure what you mean. The orginal cluster comes from another vehicle and I am not sure if it is locked. How can I find out? Thanks
    Mar 2020
    Thanks guys. I understand now your 00040, my car is a 4 cylinders but the new cluster comes from a 6 cylinders because it was 00060. So i changed that.
    But more importantly I was following Immo3 cluster swap procedure when my cluster is Immo2. I was convinced my cluster was Immo3 but apparently not. So adter following Immo2 steps everything works well. Problem solved.
    Immobilizer II Immobilizer Swapping (Instrument Cluster)
    http://wiki.ross-tech.com/wiki/index...ument_Cluster)
