Page 1 of 2 12 LastLast
Results 1 to 15 of 21
    Sep 2019
    Default Volvo S80 2005 CEM and ECM Sync needed
    Hi ,
    I have a 2005 S80 2.0T with a missing ECM, I have gotten a donor ECM and need help to Sync the ECM eeprom. This CEM is a CEM-L with Serial Number 00004XXXXXX. Heard that this particular CEM-L Serial range is more challenging.
    CEM-L Part Number: 30682981
    CEM-L eeprom: 93c86
    ECM Part Number: 30668478 (bosch 0261208289)
    ECM eeprom: 95080
    I have attach both the eeprom files.
    Appreciate any help you can offer to help sync the ECM EEPROM.
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    Tango say CEM Unknown version
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by Shmortz View Post
    Quote Originally Posted by LOSTAGAIN View Post
    Hi ,
    CEM-L eeprom: 93c86
    ECM eeprom: 95080
    maybe that's why it's unknown
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    Aug 2015
    can help if you will read M30835FJVGP
    Sep 2019
    Thanks Unfortunately, I don't yet have the interface to read the M30835FJVGP chip. I only have x-prog v5.5 and the UPA programmer at the moment.
    Are there any other programmers that can read this chip other than the E8A and Smok programmer ?
    Sep 2019
    Believe this is due to this CEM-L having Serial Number 00004XXXXXX. Seems that most of the tools only do the CEM-L with Serial Number form 00005XXXXXX.
    brend's Avatar
    Oct 2015
    Same where
    Cem dump look like crupto!
    Clon tango not work with crupto cem !
    About original tango .....
    NB!!! Don't ask in PM old file password , Im not remember.
    Sep 2019
    Any Veteran able to help? Pretty sure the CEM eeprom read is good.
    firestator's Avatar
    Oct 2010
    MINSK
    eeprom is read correctly, for further work it is necessary to read the CPU from CEM (ori xprog, orange5, smok)
    Sep 2019
    Thanks for the advice everyone.
    I looks clear that I have to read the M30835FJVGP chip.
    it will take me awhile to order a programmer that can read it. Some questions,
    1) can it be read in circuit?
    2) read in the forum that I need the CEM PIN to read it else i might end up erasing the data on it. Is there any special way to read the Renesas M32c chip?
  11. #11
    firestator's Avatar
    Oct 2010
    MINSK
    here is a diagram from xprog...
    don’t know anything about the pin (maybe there are shamanistic methods like in Chinese cars) I do these machines only by dumpsdon’t know anything about the pin (maybe there are shamanistic methods like in Chinese cars) I do these machines only by dumps
    VAG DL501 VL300 VL381 VL382 DQ381 DQ500 6HP 8HP BCM2 PCR2.1 Simos8.X Simos10.X Simos12.X Simos18.X SID208 SID807 EDC17 MED17 MED9.1.1 Immo Clone Service, Kessy all repair, Volvo all CEM repair, Rover all repair, RB4 and RB8 DEF fix.
  12. The Following User Says Thank You to firestator For This Useful Post:
    LOSTAGAIN (7th November, 2019)
  13. #12
    Oct 2017
    Hy
    I need volvo s80 2002 ecu dump sync . ori 5p08 file damaged!!!!! (2.9 t6 automata)
    ecu: 0261207227 5p08
    cem:08688434-30657428-02w416 28f400
    (cluster:9499668)
    Please help!!!!!!
    Thank you!!!!
  14. #13
    MartiLer's Avatar
    Dec 2016
    where is your dump?
  15. #14
    Sep 2014
    Hi guys, I need help, my cem got wet and it's my turn to change it. I don't have data from the old cem. The eprom was sulfated. I only have micro CEM reading. Can someone match this CEM with the original ECM of the vehicle?
    CEM H 12243769_30728539
    ECM: 0261208289
    MANY THANKS !!!
  16. #15
    Oct 2017
    I upload cem file.....
