Page 16 of 21 FirstFirst ... 61112131415161718192021 LastLast
Results 226 to 240 of 303
  1. #226
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by khching2003 View Post
    ur car solve already??
    No, hoping to get some info on the repair.
  2. #227
    Mar 2010
    hi to all, have you any experience on common abs problem on mercedes ml w163 ate ecu.
  3. #228
    Feb 2018
    The pump itself or the contacts for the pump, but they seems to be fine.
  4. #229
    Aug 2019
    Hi all. I got a MK60 unit that hade the eccentric "drive bearing" rusted badly until complete blockage which also have caused the pistons to get stuck due due to corrosion.
    After cleaning the rust away with a rotating steel brush, rinsing and lubing the bearing and coating the rusted parts and sloppy silicone gasket with marine grease, the motor is running fine, And no fault codes. BUT ESP/TCS is not working. Which is surprising when potentially importan safety system is not functioning at all.
    Is there and chanse to free up the two pump pistons. Replace the seals and clean the opposite surface in the aluminium block so it will last worth doing a reconditioning job?
    Or is buying a new or reconditioned unit the only safe option?
    Cheers Gunnar
    Sent fra min Moto G (5) Plus via Tapatalk
  5. #230
    Aug 2019
    Som photos. Pump house before cleaning. And motor after cleaning..
  6. #231
    Oct 2018
    egypt
    i have mersedes w204 with esp problem of (5001 there is an internal fault in control unit n30/4) ... tried road test and checked abs wiring and connectors but all seems to be ok ... fault can be erased but comeback when vehicle reaches about 30 km/h ... here also a photo that may be helpful
    wbr.
  7. #232
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    hi...
    we have a broken ABS/DSC unit BMW E36/Z3 from 2002...
    we found a used one, same part number...
    when we built in, does we have to change VIN/coding like on VAG or something else...?
  8. #233
    Sep 2009
    right here right now
    Yes you will have a dtc for incorrect vin and will need a tool to change this.
    Sent from my H8216 using Tapatalk
  9. The Following User Says Thank You to smokinjoe For This Useful Post:
    figani (26th September, 2019)
  10. #234
    figani's Avatar
    Feb 2018
    Quote Originally Posted by smokinjoe View Post
    which tool will help...?
    will dtc only be stored, or will also some of the lamps in dash burn...?
  11. #235
    Sep 2009
    portugal-ourem
    Good Morning. I have this ABS drive mk60 € bmw E46 with error 5DF5. can someone help me with this
    6759047 10.0960-0811.3
    Enviado do meu Mi A2 Lite através do Tapatalk
  12. #236
    Jun 2010
    Europe
    I have a few dozen of these in the attic all with 5D5F or similar internal faults. Mostly with ABS only but the problem is the same. I would be very happy to know the cause of these faults.
  13. #237
    Aug 2016
    My ABS MK60ec1 on Golf IV got 01130 error.
    I resoldered all PIN at the side which is connected to ABS cable.
    The error is still there.
    How could I do next?
  14. #238
    hi to all, how to solve this mk26 abs unit from mercedes with fault code 5001
  15. #239
    Nov 2009
    Quote Originally Posted by ristici View Post
    Is this related to brake pressure sensor or does it give a different error?
  16. #240
    dijo's Avatar
    Apr 2010
    Hi, here Laguna2 With ABS DTC DF185 Internal Supply Servo Solenoid active Valve Circuit...
    any Idee...?
  17. The Following User Says Thank You to dijo For This Useful Post:
    mohamed2007 (31st May, 2022)
