Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Aug 2020
    Default AUTOCOM DELPHI DS100E DS150E VCI FAULTY CHINESE DEVICES 2021!!!
    THREAD CLOSED
    HaynesPro online + 2022.02a version available, message for where to get it!
  2. The Following 4 Users Say Thank You to crouchinggerbil For This Useful Post:
    abe160 (27th January, 2021), Jukica (29th October, 2021), taammm12 (12th December, 2021), TheUnknown (11th April, 2021)
  3. #2
    Dec 2020
    I Have this same board and could not get it to work neither on usb nor on Bluetooth. I found that the FTDI chip is fake because it does not sotre the settings with Mprog 3.5 and it does not have EEprom inside as Mprog reported that no EEPROM found.
    When plugged to usb it is installed as the standard FTDI driver as serial prot and not as VCI diagnostic. The driver from cd is not accepted (because it is fake ftdi with fake serial number A50285BI)
    So I gave up and tried to use bluetooth because i think it will work but it did not work. The computer detected the device Autocom CDP+ BT 100953 and the pairing is ok with pin 0000, but when I try to connect to the car it says the same as with usb: the vehicle is not reponding and relay are clicking with Lights changes from blue to green and it take more than a minute to get error not responding.
    3rd try: I removed the FTDI232RL from the bord hoping that may be there is a short or someting but the same relay clicking and no response.
    Any advices please.
  4. The Following User Says Thank You to drwoong For This Useful Post:
  5. #3
    Aug 2020
    Quote Originally Posted by drwoong View Post
    Any advices please.
    I hope to have the one in the pictures some time next week. I can swap with real ftdi chip and see what happens.
    Honest advice is buy a proper one. I would not get much hopes for this one to work.
  6. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    drwoong (10th January, 2021)
  7. #4
    Dec 2020
    Yes, I hope it will work with real FTDI chip on usb. But the problem is that mine is not working on Bluetooth too with same behavior. Is the Bluetooth circuit independant from USB circuit? If yes .. why it does not work on bluetooth.?
  8. #5
    Aug 2020
    You CAN NOT update firmware through bluetooth. If we cant access through usb to see if we can upgrade then bluetooth will give us less
  9. The Following 2 Users Say Thank You to crouchinggerbil For This Useful Post:
    drwoong (10th January, 2021), Jukica (29th October, 2021)
  10. #6
    Dec 2020
    Ok thanks bro. That is a problem for me because i can not get a real ftdi chip right now on my country
    Please tell me the resutl when you will replace the chip. Thanks bro.
  11. The Following User Says Thank You to drwoong For This Useful Post:
    crouchinggerbil (10th January, 2021)
  12. #7
    Top Poster luisfm's Avatar
    Feb 2013
    Quote Originally Posted by crouchinggerbil View Post
    Hey guys it has come to my attention that the chinese are getting cheaper again!!!
    I had a customers VCI before xmas and now another guy with the same VCI have problems.
    First one the Firmware would neither upgrade or downgrade!!! Reflashed the ftdi chip from a good one also no good.
    Second one would not respond when installing driver. Starts to install then fails when VCI is plugged in for the serial port driver.
    THESE ALSO ONLY HAVE A HALF SIZED PCB WITH JUST 12 RELAYS AND NOT 20
    Attachment 775362Attachment 775364
    REMEMBER TO CHECK PICTURES BEFORE YOU BUY!!!
    Hello, I have 2 vci and I would like you to tell me if they are good or defective
  13. #8
    Feb 2018
    these are your best boards, especially the one with one board
  14. The Following User Says Thank You to zoki21 For This Useful Post:
    crouchinggerbil (9th February, 2021)
  15. #9
    Aug 2020
    Quote Originally Posted by luisfm View Post
    Quote Originally Posted by zoki21 View Post
    Yes them ones are good boards.
  16. #10
    Aug 2020
    Potential fix for those of you with one of these vci's
    Use stlink ( like this: https://www.easytronics.com.br/st-link-v2 )
    With STM32CubeProgrammer write any bin version, them write eOBD_VCI+.hex and OBD_VCI+.hex.
    You can use bin files from here: https://www.digital-kaos.co.uk/forums/sh...not-FOUND)
    This is how I upgraded my DS150e.
    Be happy.
    Also take a look at this: https://www.tlemcen-electronic.com/forum...hp?t=36605
    Credit to OP sidmoraes
  17. The Following 2 Users Say Thank You to crouchinggerbil For This Useful Post:
    karageorgos (30th June, 2022), nbtechnic (12th May, 2022)
  18. #11
    Feb 2018
    is this autocom gold diagnostics 30250, what is obtained with this modification, I have the same, only with white nec relays and oki chip, it works well without problems.
  19. #12
    Aug 2020
    Thats just an example board of what to do with these new ones.
    Procedure to reprogram the chip manually that will not update via usb.
    sidmoraes did this procedure on the new vci and he got it updated.
  20. #13
    Mar 2009
    One more info.
    Wow version 5.00.3 does the trick.
    Other versions don't.
  21. The Following User Says Thank You to sidmoraes For This Useful Post:
    crouchinggerbil (16th February, 2021)
  22. #14
    Aug 2020
    Quote Originally Posted by sidmoraes View Post
    One more info.
    Interesting, i must try that if i receive another board like this one.
    Cheers mate.
  23. #15
    Nov 2016
    Can someone tell me if my VCI is any good or bad, it works fine for my use, I'm only a diy'er and in the 18 months or so since I have bought it it has served me very well, the firmware updated just fine, and thanks to crouchinggerbil I'm running Autocom 2017 v3, and it has done all I have needed. Just curious to known if what I got is any good.
    Thanks in advance!
