Image Pin code
  • Solo1969
    • 5
    Image Pin code
    Hi all wounder if anybody could help me by giveing me the pin code for
    the new updated image V++ Nokia x2 AU fixed i have tried 1234 but thats says wrong pin Cheers guys Thanks in Advance Sorry the image was on this site and it was added 28th April, 2008 by Rob_roy Thanks again
  • xenafan
    • 64
    The default pin is usually 0000 zeros try that.
    Cheers
    xenafan
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      If you know the ip address and can ftp to the box, the pin will be stored in the /var/tuxbox/config/neutrino.conf file.
      • DBO
        • 10
        ya can find this out to ways via box or ftp.......the way i will tell ya is via box.
        1. press blue
        2. select tuxbox commander
        3. find var and hit ok
        4. find tuxbox and hit ok
        5. find config and hit ok
        6. find neutrion.conf and hit ok
        7. scroll down till you find parentallock_pincode and you will see the pin you need next to it
        7. to get out of all this just hit home button a couple of times
        regards
        Dave
