Page 469 of 854 FirstFirst ... 369419459464465466467468469470471472473474479519569 ... LastLast
Results 7,021 to 7,035 of 12803
  1. #7021
    Nov 2017
    7.0 works fine with 18.2 polish and 18.9 english ?
  2. #7022
    May 2010
    EU
    You can try any combination you want. If doesn't work you can start all over with the same hardware. No need to put it in trash bin and buy another.
    Yes V7.0 works fine with 18.9.0 english released before 18th october.
    Read page by page backwards and learn new things. Spoonfeeding is in RT forum
  3. #7023
    Apr 2018
    Hello. Im locking for French 18.9 vcds. Can some one share it. Thanks.
  4. #7024
    Oct 2018
    Thank you !
  5. #7025
    mapexo's Avatar
    Mar 2017
    Germany
    VAGCOM_HWType FW Version : 1.96
    HW Version : 0x44
    Identification : ROSSTECH !
    chip installed cable:
    ATMEGA162 16AU 1604M
    ftdi ft232rl
    mpc2515
    mpc2561e
    atmel atf16v8b 15jc 0218
    l9637d x 2
    have problem sometimes I have a "communication error" and software crashes car diaologhe, why ! Used sw vcd 18.9 ITA and loader v6....?
  6. #7026
    May 2010
    EU
    Can you try the same with v7.0 loader?
  7. #7027
    mapexo's Avatar
    Mar 2017
    Germany
    not have loader v7 sir
  8. #7028
    Oct 2018
    Hi! Quick question; What's the easiest way to connect VCDS cable (2018 version HEX-V2) to 12V when writing/flashing with VAGCOM_EEWriteLang? I'm thinking of attaching a + wire to pin 16 and a -wire to pin 4 or 5 on the OBD-2. Is it safe, and will it work?
  9. #7029
    Oct 2017
    Germany
    Yes this will work
  10. #7030
    Feb 2017
    Poland
    Quote Originally Posted by SaraLee View Post
    Look at links at the end of this post: http://www.digital-kaos.co.uk/forums...=1#post3401808
  11. #7031
    Oct 2017
    Germany
    Quote Originally Posted by mapexo View Post
    Read some pages backwards. You will find a lot of links. And if you plan to use the DRV (german) version: You need VCDS-DRV-18090-Installer-exe with SHA256 HASH
    dec418bad568dd4934731a1c20ffd56a2857aaca5658e91a03 b4fd73d34ada76
  12. The Following User Says Thank You to networkers For This Useful Post:
    mapexo (22nd October, 2018)
  13. #7032
    mapexo's Avatar
    Mar 2017
    Germany
    have resolt, worked interface used loader v7, thankyou!
  14. #7033
    Oct 2017
    The sha256 hash of the 18.9.0 drv installer that I've got a few days ago is be03a248c59755ed7d69dfcf6f725cca77185af6bb0ecf7f7a 47960646048407, the digital signature is from 05 Oct 11:07 and it works just fine. How many different versions are out there?!?!
  15. #7034
    Apr 2016
    Quote Originally Posted by networkers View Post
    Attachment 566066
    Yes this will work
    Picture cabling is correct but the labelling is wrong. -12v should be 0v (or GND for GrouND).
    I just used an old 12v netgear router power adapter by cutting off the connector end and soldering a suitable pin socket onto the 0v lead and another onto the +12v lead:
  16. #7035
    Oct 2017
    Germany
    Quote Originally Posted by MacNB View Post
    Yes, you are right. This would be 100% correct. It should be for illustration purposes only. But anyway, the picture is updated.
