Results 1 to 14 of 14
    Dec 2018
    Default What tool programming ??
    I’m going to programming the EEPROM and SRS module, and I had a lot of searches on tools and software but now I’m confusing what to choice?! CarProg, xProg, UltraProg, Kess, UPA usb, …
    I’ve understood that the CarProg is well for start. But I have some questions, please help me.
    My questions:
    1. What device is more suitable to start? (Especially for SRS ECU programming and Low risk)
    2. What's different between Carprog and Kess and K-tag?
    3. What does different between CarProg versions (10, 8, online and offline)? Original or clone?
    4. Does Carprog have this feature that uses third-party eeprom programming software? What device does it have?
    5. Does the CarProg support eeprom chips?
    I read that the clone version does not support eeprom 24c**,25c**,93c**,95***... !!!
    These are important to me:
    • SRS module Programming and Airbag resetting, most Asia (Honda) and American cars.
    • I’ve electric and IT knowledge but looking for a low risk tools for start.
    • I’m going to Start with low budget then grow up.
    I’m not a professional but I love electricity and programming specialty IT. Please help me to improve my knowledge.
    Thank you so much for your help,
    DWT's Avatar
    Oct 2018
    Quote Originally Posted by meysam98 View Post
    1. Carprog china clone is a best choice.
    2. Carprog is using for airbag, dashboard and for pullin PIN from Opel ecu. Kess/Ktag is made for flashing ecu.
    3. Use only clone whith 8 online, another versions doesnot work. Original have terrible price.
    4. Carprog can read and write eeproms and you can change this dumps by another programms.
    5. Yes.
    DWT's Avatar
    Oct 2018
    Bad clone does not support. Good clone works fine with all eeproms.
    Dec 2018
    AT HOME
    I will order it in the days to come, I will share my experience with you
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    UltraProg for airbag. It's software + hardware + programer tool. Unlimited use even after 1 year. Fees around 80euros.
    You can find the manufacturer on dk forum and also on eBay.
    Envoyé de mon SM-G950F en utilisant Tapatalk
    Mar 2020
    Cool
    salut didi du 93 JE SUIS NOUVEAU SUR CE SITE ET JE SUIS DE VARREDDES 77 DIS MOI EST-CE TU PEUX M'AIDER STP POUR UN BOITIER AIRBAG TRW 391248 A45190115000 merci d'avance sinon tu as AUSSI le shemas par pinout STP
    Mar 2020
    COMME OUTIL J'utilise le carprog version 731 MAIS IL YA PAS LE PROTOCOLE
  8. The Following User Says Thank You to tofy971 For This Useful Post:
    lupen115 (22nd March, 2020)
  9. #8
    Nov 2019
    car.jpgCiao amici, ho appena adornato CarProg v8.21 online, spero che mi mandi quello buono, non so se posso pubblicare il link
    che pubblico una foto.
    consiglio da parte di tutti voi grazie
  10. #9
    Jan 2010
    Can anyone recommend good carprog clone that works with all EPROMs like original??
    Sent from my iPad using Tapatalk
  11. #10
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by didi_du_93000 View Post
    hi. ho, is a person manufacturer ultraprog interface+software 80€.... i wait for your reply
    thankjs
  12. #11
    fuzz1's Avatar
    Jul 2019
    If you are going to use it for eeprom then use the cheapest. Ch341 does the job
  13. The Following User Says Thank You to fuzz1 For This Useful Post:
    pawl (21st November, 2023)
  14. #12
    electronistul21's Avatar
    Nov 2011
    galati,romania
    you can considere and Orange5 V1.38,have many solution for airbag
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  15. #13
    Dec 2009
    France Paris
    Quote Originally Posted by javiercj View Post
    thankjs
    My message it's from 2018.
    Price is higher now.
    Check his website.
    Envoyé de mon SM-F946B en utilisant Tapatalk
  16. #14
    Jun 2022
    During the development process, it was important to maintain transparency. Regular updates and demonstrations of interim results helped me keep my finger on the pulse of the project and make adjustments if necessary.
    Once the development was complete, testing was an important step. Together with the custom java development https://broscorp.net/custom-java-development-services/ team, we thoroughly tested the functionality, identified and eliminated possible bugs.
    The project was successfully completed and I got exactly what I wanted! The customized Java development exceeded my expectations. Now my solution fully meets my business needs and even provides additional possibilities for expansion.
