Correct! Is 46. 34-35 not connected
The best solution would probably be to take a tester and check.
I have checked it both pins have no connection to the GAL... kolimers tool says it is 0x44...so i have to flash 0x46 with an usbasp right?
I downloaded direct from R$ site http://www.vag-com-portugues.com/
So is it safe to say 19.6.1 is working good? No more problems like with the 19.6.0?
Each new version comes with bug fixes and new bugs.
Just by testing you will find out if everything is fine or not!
Each new version comes with bug fixes and new bugs. Just by testing you will find out if everything is fine or not!
Hello people!
According to the suggestions of users in this forum I bought this interface with option/software VAG 18.9 Romanian:
https://www.obd2cartool.com/atmega-v...hipping-p-1554
Arrived to me today, but on the provided CD disk is nothing (is simply empty!). How can I obtain the software and the instructions for using this interface?
Thanks!
or read the info/readme pdf ....................
Mandyno (15th July, 2019)
please delete
