Fabio89 (4th July, 2020)
So, 2Q-19.clb doesn't contain redirect for your 2Q0-937-089-B.
That's why you copied 5Q0-937-08X-V2.clb to Labels\User and renamed to 2Q0-937-089-B.clb
You see that clb file gets read in your opened #09 controller.
Anyway, this file doesn't support coding information. It has security access code 31347 for J519 adaptation enabling.
ITT, PTT and EST released.
mindafuttu (7th January, 2021)
also with Loader 9.2
by Audi A4 or VW Touran after 2016 doesn't work good and you can not read the 53. Brake settings
can someone tell me if there is a new update Loader from Kolimer that can solve this problem?
Thanks a lot Kolimer and all Digital Kaos Users
lolren2 (5th July, 2020)
Hi all. I've started to read all the posts, but it will take some time as English is my second language
Until then, just wanted to ask about my VCDS clone. It works, but it says CAN: not ready. I will require to activate my cd changer function in my cd player. When i scan for radio, it communicates with it( volume change) but i get a error saying : too many errors.
It's there a way to reflash it?( Hw type shows 1.96 and no info about bootloader)
Kind regards, Loren
Edit: yes, it has the Atmega 162 chip inside
Sent from my Redmi Note 8 Pro using Tapatalk
Will this 9.2 Loader work with AKP 20.4.1 (Polish)?
razor1199 (7th July, 2020)
Thanks to a forum member, I've managed to flash 1.96 using vagcom eewritelang( bootloader is enabled), but, sadly problem persists( can: not ready). When i scan the radio, for example, i get the volume changed as it scans, but then i get : too many errors to continue. You guys think is a hw issue? Thank you
20.4.1 Spanish version works with 9.2
Hi, after update the vcds to latest version vcds loader 9.2 with all success, bit i have got one error: Can Unavailable
https://ibb.co/vjv9MD3
https://ibb.co/FKqH5VQ
https://ibb.co/ZM4Txty
Any fix for it?
Version VCDS-ROJ 20.4.1 Data version: 2020.07.09 DS317.0 with updated database is downloadable.
Version date
liviudiaconu (10th July, 2020)
reflash FVDI
