Andrey1842 (17th January, 2021), Aucor (9th February, 2021), Bastard2 (19th January, 2021), bedrock (18th January, 2021), borian (18th January, 2021), bvm5by (17th January, 2021), Col19 (6th February, 2021), Creteil (17th January, 2021), ESPRIT (17th January, 2021), jan4 (17th January, 2021), kaalis (17th January, 2021), miouser (17th January, 2021), Tib82 (18th January, 2021), Toljanoss (17th January, 2021), xlv600 (6th November, 2023), zemaitis (17th January, 2021)
Good Job![]()
badrax (17th January, 2021)
Does the upgradable 405 behaves the same when upgraded using the VIIPlusLoader? (Will the LED blink like on the video)
Don’t know if this will work on the upgradable one using the VIIPlus. Cloners (fly) clams they made own firmware and perhaps own bootloader.
Will be a bit confusing naming these cables from now since they all support upgrades
My POC only shows that it is possible to upgrade these cables. We still need a new firmware to upgrade to.
And also. If we could get one say from the VIIPlusLoader then it will require the hardware (pcb) to be compatible
Good Job !!!
Buy VCDS Hex-V2 from aliexpress
https://www.aliexpress.com/item/1005...6bae4edfKNwPWm
And the tool vcdsusb.exe can be downloaded?
