Page 691 of 854 FirstFirst ... 191591641681686687688689690691692693694695696701741791 ... LastLast
Results 10,351 to 10,365 of 12803
  1. #10351
    Aug 2020
    Quote Originally Posted by jan4 View Post
    no external 12v
    Of course i wasnt watching for power
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  2. #10352
    Sep 2015
    Quote Originally Posted by nextor View Post
    Another guy (crouchinggerbil) said that it seems to work fine. Do you have it and it's not working as it should? If yes, what is not working well? Thanks!
    Sorry, bad picture of type A, but if there is ATMEL MEGA162-16MU chip, that's fine.
  3. #10353
    Dec 2020
    Tested my 415 upgraded to support VCDS 20.12 on my electric 2019 car
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    23-Brake Booster -- Status: OK 0000
    29-Left Light -- Status: OK 0000
    39-Right Light -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    4B-Multifunc. Module -- Status: Malfunction 0010
    51-Electric Drive -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    75-Telematics -- Status: OK 0000
    8C-Hybrid Battery -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
    BD-Hi Volt. Batt. Charg. -- Status: OK 0000
    C5-Therm. mgt. -- Status: OK 0000
    C6-Batt. Chrg. -- Status: OK 0000
    D6-Light Ctrl Left 2 -- Status: OK 0000
    D7-Light Ctrl Right 2 -- Status: OK 0000
    Looks like it supported them all. I used auto-scan and holy shit it was fast compared to my older genuine HEX-CAN interface which took ages to complete scanning.
    Was playing around in vcds and everything seems to work just fine. Did not test any coding so don't know if that works yet
  4. The Following 11 Users Say Thank You to badrax For This Useful Post:
    Anydraj (12th February, 2021), Aucor (10th February, 2021), Creteil (10th February, 2021), crouchinggerbil (10th February, 2021), drdahmani2 (29th January, 2022), DreamLand69 (13th February, 2021), jan4 (10th February, 2021), mrle9 (10th February, 2021), nicu1979 (14th February, 2021), paro44 (12th February, 2021), Toljanoss (11th February, 2021)
  5. #10354
    Oct 2016
    Hello badrax
    Your vcds hexv2 work with loader or not?
    Thks
  6. #10355
    Mar 2019
    badrax, which loader version are you using (if any)?
    some reported bugd and errors with latest 08.021.03
  7. #10356
    Nov 2020
    Quote Originally Posted by bg17aw View Post
    please use VIIPlusLoader-08.021.03
  8. #10357
    Jun 2010
    badrax is working on the development of the update for a « STM32F415 » chip, until now, it was not possible...
    Also, until now, it is claimed to use a « STM32F405 » for the reason given above.
    Are you sure at your side you have a « STM32F415 » based cable ?
    By the way, for now, like badrax say « Was playing around in vcds and everything seems to work just fine. Did not test any coding so don't know if that works yet ».
    So, it would be better to wait another time for badrax making some tests about coding on recent platform, to be sure his work can benefit to others users with this kind of interface...
    At your side, if you asking what version of loader you need to use, then, you probably have a « STM32F405 » chip based cable.
  9. #10358
    Oct 2018
    Hello badrax, where can dwonload eeprom and flash, i have many STM32F415 cables
  10. #10359
    Dec 2020
    Quote Originally Posted by BILAUTO View Post
    Hello badrax
    Thks
    My 415 does not work with the VIIPlusLoader. Reason is that the firmware bundled in this loader checks the present of the extra "encryption" chip and this need patching.
  11. #10360
    Dec 2020
    I am not using a loader but I am using the firmware embedded in the loader version 08.021.01. That should be firmware version 01.02.05.
  12. #10361
    Dec 2020
    Quote Originally Posted by obdcarsale View Post
    Nothing is yet available. My POC used the STM tool to flash over the debug port and I need to do some changes on the 415 bootloader for it to accept this new firmware.
    This will most likely require a full reflash of the 415 and I don't have this code ready yet.
  13. #10362
    Dec 2020
    I flashed my 415 back to the original firmware it came with and used VCDS 20.4.1 to test on my same electric car.
    This is the auto-scan list it produced:
    E0-Auxiliary Display 1 -- Status: OK 0000
    And you can see that these are missing from my last test (using 405 FW 01.02.05):
    And this is new on the org fw:
    One thing I noticed which are the same for them both is that module "03-ABS Brakes -- Status: OK 0000" shows OK without a fault but when the module was scanned it actually contains a fault:
    Fault when using 405 FW:
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Component: ESC
       Revision: 00000000    Serial number:
       Coding: 01FA40A12C21216E477C060361CA2980023484E26086943338915078C2E203
       Shop #:
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
       ROD: EV_Brake1UDSContiMK100OMG_003.rod
       VCID:
    2 Faults Found
    8400 - Databus
              U1123 00 [032] - Received Error Message
              [FCAN: AB_Gurt_FA signal is invalid]
              Intermittent - Not Confirmed - Tested Since Memory Clear
    16401 - Tire Pressure Warning
              C102D 00 [032] - -
    Fault when using org 415 FW:
       Component: ESC
       Shop #:
       VCID:
    2 Faults Found
    8400 - Databus
              [Tip-TNF 239934]
              C102D 00 [032] - -
    It does not show the same text but I guess this could be coz of VCDS 20.12 vs 20.4.1?
  14. The Following 8 Users Say Thank You to badrax For This Useful Post:
    Aucor (10th February, 2021), Creteil (10th February, 2021), drdahmani2 (29th January, 2022), Fabio89 (12th February, 2021), hid3 (7th April, 2022), jan4 (10th February, 2021), kaalis (10th February, 2021), paro44 (12th February, 2021)
  15. #10363
    Oct 2018
    Try to use both 20.4.1. If you can.
    I had bad situation when I was trying to use vcds 18.2 loader with vag-com 17.8 (old eeprom). All information was different in coding and adaptation. Like another car.
  16. #10364
    DK Veteran WOODWARD395's Avatar
    Apr 2010
    Manchester UK
    hi which is the latest VIIPlusLoader for 405 chip has anyone a link to it please. many thanks.
    Education is not the learning of facts, But the training of the mind to think
    So hit the thanks button if I have enlightened you.
  17. #10365
    Aug 2020
    Quote Originally Posted by WOODWARD395 View Post
    Here you go mate
    https://www.digital-kaos.co.uk/forum...UAL-NO-PASS!!!
  18. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    WOODWARD395 (12th February, 2021)
