Page 1 of 2 12 LastLast
Results 1 to 15 of 25
    Default NEED PIN FROM UCH CLIO RENAULT
    HI
    CAN I HAVE PIN CODE FOR CLIO III FROM UCH
    1.5 DCI 85
    BCM L2CR 8200811816
    28120982-4B B V12.12
    EEPROM 95160
    Top Poster andresfn18's Avatar
    Feb 2010
    Mexico D.F.
    the only solution i would recomend is tm-pro2 for key programming, no show the pincode!!!
    tmpro?
    dont know it!
    can i have a good reseller and price!
    how works,?
    MANY THANKS
    Feb 2010
    Mexico D.F.
    Default TM-PRO
    THIS IS HIS WEB
    Transponder Maker Pro 2
    IT`S AN EXCELLENT PRODUCT, VERY RELIABLE AND EASY TO USE!!!
    someone know if this reseller is good?
    i want to order his tmpro
    Feb 2010
    Mexico D.F.
    BOGI IS NOT A RESELLER, HE MADE THE TMPRO2,
    VERY RELIABLE AND GOOD FRIEND.
    Dec 2009
    huntingdon cambs
    or you could use the zedbull
    RENAULT/DACIA OBD
    Quote Originally Posted by nabby View Post
    RENAULT/DACIA OBD
    thanks but read first post!
    i want solution to programm keys for CLIO3 2005 -> 2010
    I RECEIVED MY TMPRO TODAY ORDERED FRIDAY PRICE 400EUROS
    BULGARIA TO FRANCE
    I WOULD KNOW IF I CAN PROGRAMM VIRGIN REMOTE CLIO 2 with TRANSPONDER pcf 7946 IN A CLIO 3
    UCH CLIO 3 USE KEY WITH TRANSPONDER PCF 7947
    THANKS
    Feb 2010
    Mexico D.F.
    Default pcf7936
    I only program pcf7936, i never try to program the control key, i don`t have idea!!!
  11. #11
    i bought tmpro can you explain me how it works please
  12. #12
    Feb 2010
    Mexico D.F.
    Default clioII
    Quote Originally Posted by MEH View Post
    YOU MOST READ THE EEPROM INSIDE OF BODY IT IS A 95160, THEN SAVE THE DUMP IN BIN FORMAT, THEN CALL THE DUMP WHIT TMPRO2 AND TMPRO PROGRAM THE CHIP IN YOUR FILE, THEN YOU WRITE THE NEW FILE IN THE EEPROM.
  13. #13
    THIS IS WHAT I DID BUT NOT WORKING
    WHY
  14. #14
    Feb 2010
    Mexico D.F.
    sorry for late, put the new transponder nearest of the ring or out of the key!!! and post your new dump
  15. #15
    Feb 2010
    Mexico D.F.
    Default example!!!
    this is just an example it works fine!!!
