Results 1 to 15 of 15
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Default Utility for TECH2 and PSG16
    hello
    does someone have this soft for 32mb card for extracting flash from psg16.
    Utility for extracting / welding PSG16 OPEL files from TECH2 32MB card. With it you can extract calibration data form 32 MB card and after tuning file you can merge data back to the 32MB card .
    regards
    Here to HELP!
    Jun 2013
    EU
    I guess people just cut it manually with hex editor.
    mancioks's Avatar
    Feb 2017
    Germany
    Manual work always.
    If i helped, don't forget push thanks + rep
    Jun 2013
    EU
    Quote Originally Posted by mancioks View Post
    Manual work always.
    Do you know if offsetts in 32Mb file are always same? Or is needed make some kind of search inside the pcmcia image to find the ecu dump?
    If you give me some clues i can code a little app to automate the work.
    mancioks's Avatar
    Feb 2017
    Germany
    I think for each tipe ecu offset in pcmcia is different, but if find it one time for psg16 it will be always there. I had only done psg16 and edc15m and start was in different places.
    Jun 2013
    EU
    If you can post link with a pcmcia image with psg16 dump and its offset i make little tool to extract and reinsert psg16 dump into it.
  7. The Following User Says Thank You to morgano For This Useful Post:
    konq100 (22nd April, 2019)
  8. #7
    Jun 2013
    EU
    Hi mate.
    Thanks for sharing the PCMCIA image and its locations. As promised here is little tool.
    I hope everybody likes it.
    Super easy to use, just 2 buttons, one Export that makes you choose PCMCIA image and after validating it extracts the readed PSG16 dump and writes it in the same folder of the tool. The other button is Import, makes you choose two files, one is the PCMCIA image you want the PSG16 dump inserted in, and the other is the modded PSG16 dump to be inserted, after validating produces new PCMCIA image in the tool folder. By default uses .bin extensions, but you can manually select any file regardless of its extension. And everytime it produces a file overwrite the old one without asking, so be careful with this
  9. The Following 16 Users Say Thank You to morgano For This Useful Post:
    bobolin4o (23rd April, 2019), immokill (23rd April, 2019), johak (6th September, 2019), mancioks (23rd April, 2019), marsher (8th January, 2023), mastaflex (24th April, 2019), mbtun (15th June, 2022), meco (9th November, 2023), mexanico1971 (19th June, 2020), mzabka (9th January, 2020), pugbug (6th September, 2019), s2000 (29th November, 2020), Tobby_35 (24th April, 2019), tobyb (6th October, 2019), zlukic (30th August, 2019), zolwx (17th October, 2020)
  10. #8
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Thanks you so much mate that is what I was talking about
    Regards
    Here to HELP!
  11. The Following User Says Thank You to immokill For This Useful Post:
    morgano (23rd April, 2019)
  12. #9
    Jun 2013
    EU
    It is very simple app, but functional anyway
    Glad you liked it.
  13. #10
    mancioks's Avatar
    Feb 2017
    Germany
    Quote Originally Posted by morgano View Post
    Hi mate.
    Nice to cooperate, i think it will be usefull for all
  14. The Following User Says Thank You to mancioks For This Useful Post:
  15. #11
    Jun 2013
    EU
    , 17 downloads but people still resist to comment and press the Thanks button.
  16. #12
    Nov 2016
    Very useful tool, take out the work of manually editing, it doesn't appear to work for saab pcmcia? Maybe I'm doing something wrong
  17. #13
    Nov 2018
    Glad you liked it.
    I was wondering theres is a chance to download it? I cant download it to sad.
  18. #14
    Jun 2013
    EU
    Sure, when you’ll become an active member sure forum will let you download.
    The updated version is here
    https://www.digital-kaos.co.uk/forum...G16-and-EDC15M
    Probably SAAB psg16 dump is at different offset than OPEL. That is why tool failed for SAAB. But can add SAAB support if someone give correct offsets.
    Regards,
  19. #15
    Nov 2018
    Thanks a lot
