Gagik1984 (20th May, 2017)
Not seen tacho in this cluster before can it not be done in coding with vagcom
I reed dump after make adaptation with vcds (33 chanel, trip logger - 0). I not have dump before coding procedure. The big "T" and ---- on cluster is gone, but speedo and temperature not work. Please help
Vag com will sort this out its in adaptions
Adaptation not work for me. I need tacho off dump.
Dashboard - 7H0920851R
Problem solved. Thanks!
mcd76 (21st October, 2014)
same trouble i have after disable tacho in t5 with vcds, i solved by cloning parts of dump from original dump and dump without tacho, this is all my try
HI!
I have a similar problem.
Please help me!
thx
please remove tachograph from dash
VW Transporter T5 2003
7H0 920 851R
VDO - VWZ7Z0F
6N0909901
sw: T5V02
93c86
ampibali (3rd July, 2023), audiopoint (14th October, 2016), condorneck (6th October, 2017), jurarovne (19th January, 2019), mbedv (30th November, 2017)
Adaption 33-0, Disconnect tachograph. Plug yellow/ black wire B1-100ohm resistor 12v, B2 red wire ground, B3 brown wire speed signal to B8 white/blue wire. Thats it.
Hi.Need remove tachograph from dash
VW Transporter T5 2005 VDO v03 93c86
Hey guys I want to remove vw t5 tachograf
I have adaptate dash but to change dump
Berta01 (6th November, 2020)
