Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 36
  1. #16
    May 2012
    Ontario, Canada
    Default Still waiting for flashing info?
    I tried this and it didn't work, I have a blue screen before this it was screeching static, and now nothing. I doesn't seem to even respond to the remote you only hear the clicking sound when you try the reset button.
  2. #17
    Apr 2012
    Is this for a hard reset ?
  3. #18
    May 2012
    Quote Originally Posted by santiagojohn77 View Post
    ..yes, but you will need the firmware you intend to flash
  4. #19
    Jul 2012
    This comes very handy for me.
  5. #20
    Sep 2012
    Default flashing lights
    you know if you logon to router and look at client list before turning on box then refresh after you can see which ip is assigned and just browse to it
    save trying to count leds
  6. #21
    Newbie vicentium's Avatar
    Aug 2011
    Brasov, Romania
    Can't belive you didn' found an utility called "FlashWizard"; is fast indeed, reliable, tested by me and used many times (after headackes due to using Dreamup); works by LAN; you can fast backup your image first and flash another in a couple of minutes. First set connection param (IP, user, passw); use fixed IP in your DM as I did.
    Tested on my DM500-s (genuine).
    FLASHWIZARD_6_3.zip
    PM: Italian made. Unzip, open .exe file; don't need install.
    Can't be anything faster in my opinion.
    Hope it helps!
  7. #22
    Sep 2012
    Default "FlashWizard"
    Hi, I am am newbe but I think null modem cable route is easier. If "FlashWizard" method is easier somebody should do a step by step guide please.
  8. #23
    Top Poster manutd4life's Avatar
    Jan 2010
    got to the flash page, put the nfi file in and pressed flash, nothing is happening, do i need to put a different cable in or just do it from the router?
  9. #24
    Feb 2011
    Does it work with the clone??
  10. #25
    Dec 2012
    Quote Originally Posted by vicentium View Post
    FLASHWIZARD_6_3.zip
    Hope it helps!
    Which are the user and password?
  11. #26
    Dec 2012
    I could enter the Enigma Web Interface.
    How can I upload the file to unlock Sky Germany?
    Where can I got this file?
    Thank you.
  12. #27
    Feb 2013
    Hi, just got into the forum since I got an old 500s somewhere which could be useful again! Thanx for the guide
  13. #28
    Jan 2014
    hi I have a dm500s and I tried turning off power then holding the power on for 20sec but nothing happen, the lights didnt start flashing.. all that happens is the green light turns on..
    so i tried again and this time i just held down the power button for a couple minutes and still didnt work i had no flashing lights, and its definitly connected to my router because I am able to access the pli enigma screen via browser,,
    this is an old box I have and I dont have access to setup password on this box so I am trying to flash it and start over..
    really need help flashing this box pls..
  14. #29
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by s4mmy View Post
    read this
    http://www.digital-kaos.co.uk/forums...6/#post2203198
  15. #30
    Jan 2014
    edit***********
    ok i know what a null modem cable is, just need to find a store that will sell them i guess..
