Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Feb 2010
    Default NEW EX5100 "code being updated" problem
    can anybody please help me out.
    Ive just bought a EX5100 PVR of ebay.
    Updated firmware successfully,
    System information shows SW VER: 1.0 ST4 Jan 16 2009
    H/W Ver: 2.0t k5 +D
    Bootstrap v001
    SW Build: Kuro
    Done Scan, found hundreds of channels, freeview channels work fine.
    Problem:: When I select a pay channel ie Disney Channel it says "Please wait, code being updated..." but is sits there for hours doing nothing.
    Ive re-downloaded the firmware and update box, done resets and restores and re-scans. scan using 6.887..
    Can anybody help, cant find any info anywhere for this problem..
    Also, i have a MAX-V box, if i connect that in place of this do a scan using 6.887 it finds all channels and they are all fine and all viewable so i know its not code problem in my area (Hertfordshire).
    Thanks guys if you can help
    V.I.P. Member chic.'s Avatar
    Feb 2009
    glasgow
    make suru the emm is enabled
    Feb 2010
    what is emm? where do i find that?
    Feb 2009
    glasgow
    Quote Originally Posted by funky_banana View Post
    press menu and on lanuguage settings press ok then type 1968 and enable the emulation ps it unlocks the channels
    Jan 2009
    south Hertfordshire is now nagra 3, new encryption, hope your not there as it will not work whatever you do.
    Feb 2010
    ok im trying that now, when i click ok on language settings it brings language screen up:
    Menu Language - ENGLISH
    1st audio lang - ENGLISH
    and so on
    At this stage i type 1968 and the screen briefly flickers, then ive pressed red button to save.. is this correct?
    i typed 1968 again and another screen come up:
    Irdeto/Betacrypt
    Table with no entries in it. at top of table says Name, provider, key, key data
    any ideas??
    Feb 2010
    my MAX V box is workin fine, so cannot be Nagra 3 can it??
    Ive just re-installed firmware onto eurovox, just before it says Downloading is successful it says "downloading is failed", it shows failed for about 1 second and then changes to successfull???
    anyone had this problem?
    Feb 2009
    glasgow
    and so on
    Irdeto/Betacrypt
    any ideas??
    what do you mean by and so on there should be 4 english when you type 1968 it brings up the emm if this is non working then reflash the box
    Feb 2010
    Quote Originally Posted by chic. View Post
    yes ther are 4, i was being lazy typeing..
    1st Audio LANG - ENGLISH
    2nd AUdio Lang - ENGLISH
    Subtitle lang - ENGLISH
    If i type 1968 the screen flickers once and nothing changes, if i type 1968 a second time it brings up another screen called Irdeto/BetaCrypt ?? is this correct??
    It has a table with blank fields, table headings are Name, Provider, Key, Key Data
    any ideas???
    badapple's Avatar
    Dec 2008
    REQUEST
    Menu Language - ENGLISH> press 1968 here<
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
  11. #11
    Feb 2009
    glasgow
    you type 1968 once if its not bringing up the emm flash again b4 you do that try and put the keys in manually and see if that works
  12. #12
    Feb 2010
    when you say 'if its not bringing up the emm'? what should i be looking for? what does emm look like?
    if i type 1968 once it just flickers, just flashed box again and exactly the same ...
    What does emm look like, never done this before so not sure what im looking for??
  13. #13
    Feb 2009
    glasgow
    there will be 5 options instead of 4 english>english>english>english>the last one should say enabled ,put the keys in manually chances are thay wont change b4 n3 hits your area
  14. #14
    Feb 2010
    chic thanx for your help man... appreciated... BUT:
    still not working, its going in the bin in a moment ..
    Ok ive just downloaded firmware again from 4shared.com and flashed it with that incase problem with firmware on this site(which i doubt), this time when i type 1968 it does come up with EMM and its enabled.
    Now when i type 1968 again it gives me these key tables.. as i press to the right or the left it changed the CAS type, There are only key entries in Nagravision, there are NO entries in Irdeto/Betacrypt, Seca and ViAcess.. Should there be entries in here? if so where do i get the codes from, any one got a link to page? im in hertfordshire area on virgin..
    thanks for help so far
  15. #15
    Feb 2009
    glasgow
    you should have told us where you lived south hertfordshire is now n3
