Results 1 to 10 of 10
    Sep 2009
    Question VW Passat 1998 1,6 KM adjust
    What do i need to change km on this car?
    VAG-Tacho cant do it, and it cant read out the EEprom either with VAG-Tacho.
    The Speedo is a Magnetti Marelli MM4 EU according to VAG-Tacho.
    I have succesfully read out the login key, and programmed a new key for the car.
    The reason for asking, is that one of my friends just got a used speedometer replacement for his car, and he asked me if i could get the km to fit a bit better.
    The car has run just over 200.000km, but the speedo has 460101km on the clock.
    Best Regards
    obdmaster's Avatar
    Never never land
    Default tacho universal
    Quote Originally Posted by titona View Post
    Best Regards
    pretty sure a tacho universal can see attached pdf
    Not sure but find out if immobiliser is in instrument cluster, mileage might be the least of your worries after swap the car may not run
    Sep 2009
    Okay.
    Do you know if it can be done with the VAG-Tacho cable?
    Best Regards
    obdmaster's Avatar
    Never never land
    Okay.
    Best Regards
    download pdf my friend i know its for tacho universal but im sure it will help
    Sep 2009
    I have downloaded it, but i cant see how that should help me.
    Best Regards
    obdmaster's Avatar
    Never never land
    Smile
    try it as a golf iv if vagtacho has that. motometer
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    You try this ins.cluster MM4 with any sw like VAG eepromer 1.1,1.3,1.13,1,14,1.18 or other soft VW4,VW5,vagtacho usb...Many M.Marelli clusters must 80-90 km to ride after change km,and to be and,your battery disconnected 30 sec.By connected battery lead changes km is here.You try and cheers!
    Sep 2009
    Hi again
    I can choose from these in VAG-Tacho:
    I used the Passat MM4 Euro to get the login code, and it worked.
    But what should i select for KM adjustment?
    Jun 2010
    Did you solve your prolem ?
    Jan 2010
    Quote Originally Posted by majster-uk View Post
    Tacho Universal changed the odometer good
