Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    Old Git PaphosAL's Avatar
    Mar 2008
    Default DM500: Commando 15.0c online update is now LIVE
    If you're already on C15.0 then just go BLUE > BLUE > YELLOW > RED > OK (I think, LOL!)
    It's a fairly awesome upgrade that now has Bouquet Editor as the master, with AutoBouquets as it's slave, summat that someone (no names, no packdrill) said was impossible.
    Major make-overs in the RT-EPG platform, too, which might tempt you default GetEPG fans to give it a try? Loading is 80 seconds, silently, in the background, with normal viewing, OSD, and zapping. INCLUDING the 21 channels that BBC doesn't currently carry data for!
    That bit is now a one second download from our 05:30 daily tarball update, rather than 12 mins of local processing time!
    Enjoy! AL
  2. The Following 16 Users Say Thank You to PaphosAL For This Useful Post:
    00360362878 (7th July, 2014), 9bz (3rd May, 2014), anthmatthews (24th August, 2014), bugaloo41 (28th May, 2014), byy muhtu (15th February, 2017), darksky (27th June, 2015), dbeee (10th June, 2014), dr midnight (9th July, 2014), Hadron (2nd May, 2014), lewshanks (15th July, 2014), mo.p (1st May, 2014), satsmo (1st May, 2014), sigmundv (6th July, 2014), starman123 (1st November, 2014)
  3. #2
    Apr 2014
    Will download and review tomorrow
    DK Veteran scotcruz's Avatar
    Sep 2010
    S C O T L A N D
    I've updated it today.. now when I run AutoBouquet wizard.. I get the No channels were found error..
    When I do the scan and run again I get the same message.. can't seem to get the auto bouquet to work..
    Please advise if anyone got the same error
    Sent from my HTC One_M8 using Tapatalk
    Member awhitey44's Avatar
    May 2009
    Liverpool
    does anyone have a tutorial to put cccam onto this image, I have downloaded the relevant cccam file from dreamboxtools- I have chmod'd them to 755 I have placed in the var/bin/emu several times and rebooted but get no option within the image settings to install cccam. I am losing the plot. the usr folder also has a scripts file and im womdering where these go.
    any help or links would be greatly appreciated.
  6. #5
    digicon's Avatar
    Jul 2009
    Just a heads up here awhitey44 no one can give you an in depth explanation of the Cam side as it is against forum rules.
    Just to let you know though and its been posted quite a few times by paphosal himself that all the help files are on the image itself use the tuxbox commander to get to them
  7. #6
    May 2009
    Liverpool
    Quote Originally Posted by digicon View Post
    appreciate the heads up, I will try again.
  8. #7
    plasterer's Avatar
    Jun 2008
    Mersyside
    Your prob missing libcrypto.so.0.9.7 ,in your empty lib folder
    Read the help file
    As thats why there supplied with the image .............Paul
    PAUL
  9. #8
    Jul 2014
    hi,
    I am newbie here and I have few questions
    how can I sort channels in my bouquets alphabetically? and why no satellites list is available in channels list like openpli image?
    Is it possible to run auto scan without creating bouquets for new channels?
  10. #9
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    its Nintendo , different image completely
  11. #10
    Jul 2014
    Quote Originally Posted by smirnoff_rules View Post
    are you answering my questions?
  12. #11
    DK Veteran psats's Avatar
    Sep 2008
    you can sort any channel into your own order useing bouqet editor in menu same for scan
    menu services
  13. #12
    Nov 2010
    Hi there guys, love this image. Very user friendly which should help my neighbours.
    One problem however. I've flashed 15.0C from another image entirely. Managed to setup CCCam and everything else. However AutoBouquets ain't working for me at all. I 've set it to London, Sky numbering and all that, but at the end of it's run I get the following error:
    I've tried removing all the bouquets, rescanning several times will all the different "new,update,satellite-bouquet,delete" options but had no luck.
    I've also reflashed the image again via uploading to FTP and then using the Blue menu to "upgrade" the image.
    How can I get this one thing sorted, so the box is operational?
    Cheers guys
  14. #13
    Sep 2012
    hi mate i had same problem solved by doing flash erase and then flashing withh image again with r232lead and dcc
  15. #14
    May 2010
    Tried this twice (with erase flash) but cant find c*cam.
    Anyone any ideas?
  16. #15
    Sep 2008
    Quote Originally Posted by z11 View Post
    Anyone any ideas?
    you need to manualy install any camds.
  17. The Following User Says Thank You to psats For This Useful Post:
    donkalif (8th October, 2014)
