For code you need to read eeprom ST95128 and NEC processor.
hello friends i want to read eeprom rcd 310 i search on the pcb but i cannot find the right chip to read eeprom.
on the pcb i see 2 chips wich i think one of them schould be the chip to read eeprom but i cannot identify which serie it is.
one chip is 128wr st k941p
the other one is k410 st z947
the second chip is so small that i even cannot put a clip on it.
chip 1 dos not have a dot to identify pin 1.
who can help me.
cubica1 (21st October, 2019), irfa (22nd October, 2019), masterskay62 (21st October, 2019), shooting (21st October, 2019)
is that chip number 1 or 2 on my picture ?
Number 1
But you must read NEC too.
Open the software and look if eeprom 95128 is supported by your programmer.
It is recommended that you desolder eeprom from the board.
For reading NEC processor you can use any USB-to-serial converter.
Look here
https://www.digital-kaos.co.uk/forum...highlight=v850
Second option go local radio decoder
cheero (22nd October, 2019)
I tried to read with clip but i only get ffffff. I have to wait until i receive hot air to desolder that chip.
i have eeprom from 95128 who can calculate code for me?
he is calculating without nec ?
which hardware is the most easy to read the nec ?
if i follow the instructions of the next topic then i have to add a reset button, 12v and so on, maybe there is al tool which make the work more easy ?
IMG_20191111_083437.jpghy, i work with this ,calcuate alone algo ,no stres eazy to use
http://www.codecard.eu/car-radio/rcd.../prod_665.html
for the programator V850 NEC i need 12k resistor trough 12v, can somebody give me a link from ebay which resistace i need to buy and how many for this job. thanks in advance
