Results 1 to 5 of 5
    Mar 2018
    UK
    Default How I can read ISN from ECU on BMW by OBD?
    AKL E60 2007 2.0d - CAS3+
    Tango needs CAS3+ dump and ISN or dump from ECU
    Is it possible to read by OBD with KESS or FVDI?
    or must Downgrade? After downgrade what tool will need to program CAS to ECU - FVDI - AUTEL ?
    or other solutions?
    rob h's Avatar
    May 2011
    Read Cas with programmer first
    After this, you can try downgrading cas3.
    Downgrade on bench.
    What version fvdi do you have?
    Some tools read isn by obd.
    Kess does not. You Will need a full eeprom dump, ktag Will be fine.
    What ECU type?
  3. The Following User Says Thank You to rob h For This Useful Post:
    Manta1600 (16th June, 2019)
    Mar 2018
    UK
    I have - FVDI 2014
    also have - R270 and KTAG and Tango
    After downgrade how I can match CAS with ECU?
    ECU must be EDC16
    dijo's Avatar
    Apr 2010
    Quote Originally Posted by Manta1600 View Post
    I have - FVDI 2014
    ECU must be EDC16
    Hi, after you downgrade by this tools Cas...
    Ask here for help to repair your Cas dump, because it is corrupted...
    I hope you understand my hint...
  6. The Following 2 Users Say Thank You to dijo For This Useful Post:
    honkytonky (29th June, 2019), Manta1600 (16th June, 2019)
  7. #5
    Mar 2018
    UK
    Quote Originally Posted by dijo View Post
    Which tool is better to buy Autohex or Explorer ?
    Are they suitable for mileage correction on E-F series by OBD or only the bench ?
