Dreambox Bouquets
  • mab88
    • 37
    Dreambox Bouquets
    does anyone no the freq or have a bouquets with any of these channels
    i did get then but now i dont.
    Sky sports BoxOffice
    100% Babe
    Red Hot Amateur
    Red Hot All Girl
    Red Hot Wives
    Spice Extreme
  • captain chaos
    • 7
    I could do with that as well
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      These are the channels for ex-tw and ex-c&w. Not found any for ex-ntl yet.
      #SERVICE: 1:0:1:1a2f:80:f020:0:0:0:0:
      #DESCRIPTION: Adult Previews
      #SERVICE: 1:0:1:02ca:84:f020:0:0:0:0:
      #DESCRIPTION: 100% Babes
      #SERVICE: 1:0:1:02de:84:f020:0:0:0:0:
      #DESCRIPTION: Adult Channel PPV
      #SERVICE: 1:0:1:01f1:007a:f020:0:0:0:0:
      #DESCRIPTION: Other NVOD
      #SERVICE: 1:0:1:01f2:007a:f020:0:0:0:0:
      #DESCRIPTION: Other NVOD2
      #SERVICE: 1:0:1:00f5:006e:f020:0:0:0:0:
      #DESCRIPTION: TV-X_PIN
      #SERVICE: 1:0:1:00fa:006e:f020:0:0:0:0:
      #DESCRIPTION: Television X
      #SERVICE: 1:0:1:02ad:0083:f020:0:0:0:0:
      #DESCRIPTION: Adult_PIN
      #SERVICE: 1:0:1:02b9:0083:f020:0:0:0:0:
      #SERVICE: 1:0:1:02bd:0083:f020:0:0:0:0:
      #DESCRIPTION: Red Hot 40+ Wives
      #SERVICE: 1:0:1:02be:0083:f020:0:0:0:0:
      #DESCRIPTION: Red Hot Wives
      #SERVICE: 1:0:1:02c2:0083:f020:0:0:0:0:
      #DESCRIPTION: Red Hot UK Talent
      #SERVICE: 1:0:1:02c3:0083:f020:0:0:0:0:
      #DESCRIPTION: Red Hot All Girl
      #SERVICE: 1:0:1:0229:0078:f020:0:0:0:0:
      #DESCRIPTION: Playboy TV
      #SERVICE: 1:0:1:022b:0078:f020:0:0:0:0:
      #DESCRIPTION: PBoy_PIN
      #SERVICE: 1:0:1:02a5:0078:f020:0:0:0:0:
      #DESCRIPTION: Hustler TV UK
      #SERVICE: 1:0:1:00d5:0089:f020:0:0:0:0:
      #SERVICE: 1:0:1:00d9:0089:f020:0:0:0:0:
      #DESCRIPTION: Other NVOD3
      #SERVICE: 1:0:1:fff7:0089:f020:0:0:0:0:
      #DESCRIPTION: Red Hot Amateur
      Copy and paste these into your adult userbouquets file in /var/tuxbox/config/enigma/cable. This does not go into the services file.
      If you're using an ftp client, go to the /var/tuxbox/config/enigma/cable file, right click on each userbouquet file one by one and select view. At the top of the file it will tell you which bouquet you are in, i.e. Sport, Movies, etc. Find the Adult one and paste that info at the bottom of it.
      • mab88
        • 37
        is there any for sky box offices or not i dont seem to get this channel iver
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          Have a look here for sky box office...
          First of all, do this... MENU SETUP SYSTEM SETTINGS OSD SETTINGS TUXTEXT POSITION (YELLOW) Position the two right angles at the top left and bottom right corners of your tv. Doesn't need to be perfect, probably better if you bring them in a bit and not exactly on the edge. OK when done Green to save or highlight Save and
          • scurders
            • 32
            mab88 you,ll go blind watching some of those channels mate!!
            • CableFella
              • Jun 2008
              • 13
              Take no notice mab88, you won't go blind......Just stop when you need glasses!!!
              • loncell
                • Jun 2008
                • 625
                not sure if i've done it right but this is what i did :-
                I FTP'ed to my dm500
                i then opened all the bouquets till i found mine as xxx
                i then copy/pasted all the lines above and added it to the bouquet.
                i then rebooted the box and now the bouquet with all my xxx in has THE XXX channels listed twice.
                when i click on the new listed stations there all listed as the same channel number "219" and nothing appears.am i doing this right ?.meaning do i just copy/paste the above over whats already in there or after whats already there?.
                • Mubz
                  • Jun 2008
                  • 168
                  if you PM your email addy I'll can sent over a working bouquets list for
                  ex- Teleyworst with all the channels your after
                  Mubz
                  Growing old is inevitable, growing up is optional ...
                  • manj63
                    • 35
                    Dont know if any1 can help me
                    i have checked the following folder
                    using the remote control, but there is no user bouquet files in there
                    I have created my own bouquets using the blue button on remote and added channels (that work) into each bouquet and also have channels listed in all services (red button)
                    I have a 500c box which when i was given was told just to plug in and scan
                    Also can some1 tell me where all the services details should be listed (folder!!)
                    <--manj63 added 0 Minutes and 34 Seconds later...-->
                    Sorry forgot to metion i am in Glasgow area
                    • futurejack
                      • Jun 2008
                      • 5
                      I don't get them?
                      • MILLWALLFC
                        • Jun 2008
                        • 173
                        Anyone help, just did this on my Dreambox and rebooted box, all channels now there and i can select those, however all the other TV channels have stopped working except FTA ones.
                        <--MILLWALLFC added 43 Minutes and 9 Seconds later...-->
                        Loks like the keys disappeared have now readded and hoping it will work in a few mins.
                        • Donnie Darko
                          • 442
                          Probably a key roll,ex-cw rolled this morning.
                          Checkout the RED stickies massive amount of info and effort been put into them.
                          • MILLWALLFC
                            • Jun 2008
                            • 173
                            Damn do i have to downlaod new keys or will this auto update for me ?
                            • aftermath
                              • 4345
                              #15
                              Leave on SS1 for 1 minute, then reboot box.
