Part one..
Click on start
then All Programs
then Accessories
then Communications
then Hyper terminal.
see pic 1.
you should get this
Where it says new connection type in Dbox2 or anything really. Then click ok.
enter com1 like in picture.
then copy the following settings.
Then ok.
you should see a blank screen with a flashing cursor.
now connect the null modem cable to your Dbox2, make sure the box is switched off. Press the up arrow button on the front of the box and keep the button pressed in. Now switch the box on ( keeping the button in) you should see some text scrolling on your screen.
When you see the dbox2:root > you can let go of the button.
u-boot file here also RapidShare: 1-CLICK Web hosting - Easy Filehosting
Click on start
then All Programs
then Accessories
then Communications
see pic 1.
you should get this
Then ok.
