Results 1 to 5 of 5
    Jun 2009
    Default help about golf 5 steering
    hi freind's, how are you all? please i need help about a strange prob in a golf 5; 2007; after changing battery the steering lamp stay on and with vag com i get faut code :
    02546 - Steering Limit Stop: No or Incorrect Basic Setting / Adaptation
    i have try all adaptation, as say in wiki ross tech, i try changing all G85,.... but always the same prob, someone can help about this? is the any special procedure to clear this fault?
    thank's a lot in advance
    igorr's Avatar
    Aug 2010
    yesterday I change battery on my golf and I get fault somethig like steerig asistance.....
    did not sucsid to erase fault
    but after couple miles it turns of
    DK Veteran ghostridersa's Avatar
    Nov 2011
    Sometimes you need to carry out steering angle settings with vcds more than one time and must be done on a level flat road and at under 20km/h.
    . Also you must remember it
    Quote Originally Posted by aeroyas View Post
    Nov 2011
    Have you carried out setting like this:VW Golf (1K) Brake Electronics (MK60) - Ross-Tech Wiki
    Usa
    Default Steering angle adaptation
    I recently had such a case.
    After this procedure I was able to erase a mistake:
    Sensor for Steering Angle (G85)
    Important Note: This applies only for Models with Conti/Teves MK70 ABS/ASR. For Conti/Teves MK60 ABS/ASR/ESP look at Vehicle specific specific Procedures in ABS System documentation.
    Prerequisites:
    • Start the vehicle.
    • Turn the steering wheel one turn to the right and one turn to the left.
    • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
    • Ensure that the steering wheel is not moved again.
    • Keep the engine running and do not switch off the ignition.
    • System voltage at least 12.0 V.
    [Select]
    [44 - Steering Assist]
    [Coding-II - 11] or if that function is not available then use [Sec.Access - 16] instead
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 060
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a successful basic setting, field 1 should say "OK".
    [Done, Go Back]
    To make sure the basic setting was succesful, check the sensor again.
    [Measuring Blocks - 08]
    Group 007
    [Go!]
    Check field 1, the value has to be between -1.5 and +1.5 ?.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
