Results 1 to 5 of 5
    Dec 2018
    Croatia
    Default bmw E60 EDC16 530D needs dpf off
    Hi i got E60 530d 231PS 2005 that needs DPF off and EGR off solution.
    EDC 16c1 read with kess p.159
    HW 0281012190
    SW 1037390905
    if possible please erase dtc
    4166
    thanks in advance and may the rep be with you
    ivanmihov's Avatar
    Nov 2016
    Europe
    here is your file first delete all faults,then reset dpf,then write this one.All sensors must stay connected
    pass in pm
  3. The Following User Says Thank You to ivanmihov For This Useful Post:
    Roost3r (14th December, 2018)
    Sep 2016
    If you need I edit software with all sensor emulated and aif you like you disconnect sensor.
    FILE SERVICE
    macako6's Avatar
    Mar 2015
    DPF off & EGR OFF tested
  6. The Following User Says Thank You to macako6 For This Useful Post:
    benymax (3rd January, 2024)
    Dec 2018
    Croatia
    Quote Originally Posted by macako6 View Post
    forgot about pass
    thanks guys it works fine
