bmujka (28th March, 2024)
Hello mates, I need some advice from you, I received this SAAB 9.5 with Twice MCU 1D69J HC05X32 module, it seems strange to me to see so little data in the MCU, I attach a reading, none of the equipment I have recognizes the file, VVDI2, Tango or Miraclone Is it possible to provide a solution to this case?
I unsoldered the MCU from the board to read it with the original Orange5, I never tried to read it in circuit, Orange5 read and verified it correctly, best regards.
Pepelno Vds Pro
Mangarrufa Power Solutions
thank you is free
the file doesnt look good everything is FF except 0x00000010 to 0X0000001C
eliet2000 (28th March, 2024)
Correct, it is strange to see so little information in the MCU, I downloaded other Twice HC05 same mask files and it contains much more information, the file is detected by the key maker tools without problem, however this one is not, it is possible that they could have tried to do the key by OBD2 and have data been deleted? It has arrived to me in that state, there are no signs of manipulation, I am the first to unsolder it, the tool has read correctly, for my part I think I have read the only thing that was in there.
Pepelno Vds Pro
thank you is free
yeah i checked my files as well it was strange i read them with xprog i dont have issues with it.
i would try to read with xprog just for the piece of mind(even though i seriously doubt it will me any different)
Yes, i have original x prog full auth, It was more comfortable for me to read with orange 5 because of its socket at that time, I suppose I will get the same result, however I will try to read it with X prog.
Pepelno Vds Pro
thank you is free
cool good luck man post if results are different
Same read with X-Prog......
I attach the photo of the module, in case someone can provide a correct file, thank you all very much.
Pepelno Vds Pro
thank you is free
https:/ /www.digital-kaos.co.uk/forums/showthread.php/845884
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
