Results 1 to 10 of 10
    Bllinda's Avatar
    Baltic
    Post EDC16 CP39 need ASAP2, ols, a2l, kp map
    Hello Guys
    The ECU is EDC16CP 39 2.2 HDi 115 KW. Extremely heavily adjusted flash. I want to know exactly what was done in the ECU.
    Thank you for your time
    Have a good evening
    Bllinda
    today
    A topic that interests me
    Sep 2013
    upload your file, I will check mappack.
    Bllinda's Avatar
    Baltic
    I still need help
    Thanks to everyone who responded
    Good for you Friday night
    today
  4. The Following User Says Thank You to Bllinda For This Useful Post:
    nodwas (4th February, 2023)
    Feb 2018
    Hope this helps, ols file.
    pass in pm
  6. The Following 5 Users Say Thank You to tester12 For This Useful Post:
    Bllinda (26th July, 2019), Brumi1 (29th September, 2021), nodwas (4th February, 2023), pablodelhierro (9th February, 2021), Soe Lwin Tun (16th November, 2024)
    Bllinda's Avatar
    Baltic
    Post
    I'm still in the same place. I can't find the right lady file for me.
    Thank you for your willingness to help me.
    today
  8. The Following User Says Thank You to Bllinda For This Useful Post:
  9. #6
    Bllinda's Avatar
    Baltic
    There is only this one mistake left.
    Quote Originally Posted by Bllinda View Post
    Hello Guys
    Have a good evening
    Bllinda
    Architecture : I3_I4
    ECU configuration and services. VIN code :
    Test by ECU. Motor : 4HN
    Engine/Automatic Gearbox/Transmission. Chassis number or build code of the vehicle : 0
    Engine ECU. Body : Diesel. 4HN EDC16CP39 .
    Fault reading.
    associated variables
    Permanent fault. Flowmeter signal. Air flow not
    plausible
    ECU fault code : P0100
    brake press status : brake released
    engine speed : 1767 Rpm
    flow of fuel injected : 64 mg/cp
    diesel flow valve current reference value : 1284 mA
    measured rail pressure : 1145 bars
    today
  10. The Following User Says Thank You to Bllinda For This Useful Post:
  11. #7
    Oct 2019
    arizona
    I am sure that this is all stuff you already have, here is what I have as far as edc16 39.
  12. The Following 7 Users Say Thank You to boringbob For This Useful Post:
    123cocorico (29th November, 2023), Bllinda (3rd November, 2019), Brumi1 (29th September, 2021), nodwas (4th February, 2023), rocris (25th January, 2023), sergiodc (18th October, 2021), Yoso (20th December, 2019)
  13. #8
    Apr 2020
    DAMOS EDC16C39 VOILA MON AMIS
  14. The Following 2 Users Say Thank You to wisteur For This Useful Post:
  15. #9
    Dec 2015
    malaga espa?a
    pass? thanx
  16. The Following User Says Thank You to pablodelhierro For This Useful Post:
  17. #10
    Dec 2023
    C:\tuning\AI>filescsan EDC16CP39
    Searching for pattern: *EDC16CP39*
    Removing saved.txt file, Making new...
    E:\Tuning\FORD\Ford EDC16CP39
    E:\Tuning\FORD\FORD mondeo 2 mondeo 2 EDC16CP39 à verifier
    E:\Tuning\LAND ROVER\Land Rover - 2.2 TD4 160cv - BOSCH EDC16CP39
    E:\Tuning\peugeot\Peugeot 4007 2.2_HDI EDC16CP39
    E:\Tuning\Fiat\Fiat Bravo 1.9JTD 120ps tune EDC16CP39
    E:\Tuning\Land Rover\EDC16\Land Rover - 2.2 TD4 160cv - BOSCH EDC16CP39
    E:\Tuning\mitsubishi\Mitsubishi Outlander 2.2 EDC16CP39
    Found 7 directories matching the pattern '*EDC16CP39*'.
    Directory names have been saved to saved.txt.
    Anyone of thouse?
