Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    Spain
    Default Golf V 1.9 TDI 105 CV
    Hello Guys,
    I have a Golf V engine BKC, year 2004.
    It starts when i turn the key , and the spiral light is on, but if i turn the key and the spiral ligth is off, the car don't start.
    I checked to vag-com and had the next fault code:
    18009 Relay for supply voltage Terminal 30(J317).
    I checked the relay and fuses. The relay J317 is new.
    Any idea?
    Top Poster + cristi_onofrei's Avatar
    Iasi, Romania
    if you turn the key and the spiral light is off check if exit power on terminal 30 and 86 on main relay
    and is there any Fault Codes stored in the Dash ?
    Meat-Head's Avatar
    possable melted fuse box on top of battery
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by hector View Post
    Hello Guys,
    Any idea?
    Some poor contact of gnd,or rusted connectors behind fuse box?
    When does it not start,cold ,hot,wet outside?
    Ashraf6119's Avatar
    UK
    Also check for damp or water in the fuse box very common on them.
    Hope This Helps.
    Ash
    Spain
    Ok thanks, this evening i'llcheck all.It doesn't start normally in hot, in cold it starts well.thanks
    Iasi, Romania
    if is hot don't start or start hard?
    Spain
    Hello .
    This evening i've checked the car.
    the fuse box is wet and the terminal are well, not burned, no rusted. I've changed the fuse box to other car and sometimes not start.
    I've checked powers to relays, terminal 30 and 87 and it is well. I've checked the powers and grounds to engine ECU, and it is well.
    When the car not start, ( when i switch on ,and the spiral light doesn't on) then ,fan starts to running and it is impossible to comunicate to ECU with Vag-com ,as well the fuel pump relay doesn't work.
    The car to go mad to me!!!!.
    I send the wiring diagrams to elsa win.
    Any idea?
    what about fault codes in other ECU?s like Dashboard... ?
    Italy
    I had same problem with a golf4 and was the relay... you told that it's new because you have only checked it or did you replace it?
    Spain
    Hello I replaced all relay.I investigating about CAN Gateway (J533). When i check this unit and the car is missed, there isn't communication between engne ECU and Can Gateway.I belive the fault is in this ECU can Gateway.I'll triy tomorrow when the unit can gateway has to me.Thanks
  13. #13
    west midlands
    the fuseboard can play up so check for power & earths at engine control relay. this feeds the ecm & the ecm is not getting power if the glow lamp is not illumated. you can fit a remote relay to do the job tapping in to other feeds on fuseboard.
  14. #14
    Spain
    Hi m8, try to start it with a second battery, after five years, original one maybe in last starts from his life.
    Regards.
  15. #15
    You have a problem with ECU. TRy to see if have +12 and good gnd.
