Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 40
  1. #16
    Aug 2010
    Default ineed also
    Quote Originally Posted by juozas10 View Post
    Hi.
    Try this two dumps...please report...
    Dump not tested.
    Password is in your PM.
    Best regards.
    Hi juozas,
    please can you send me the pass fore this file. I need it also this file.
    Thanks a lot
  2. #17
    Aug 2010
    juozas10
    ore other surch the same clear dump for a
    SW: 8P0 959 655 C
    Bosch 0285001666
    Eeprom 95640
    or the pass
    Thanks a lot
    Frank
  3. #18
    Aug 2010
    Here the bat onee. Can someone clean or vergin it.
    95640W
  4. #19
    Jun 2011
    THANK YOU SUPER
  5. #20
    Jan 2010
    Hello
    please need to clean the same airbag
    Audi A3 Bosch
    8P0 959 655C
    0285 001 666
    eep 95640
    I can send the password for this file
    or clean my dump?
    Thanks Pablo
  6. #21
    credoline's Avatar
    Србија
    How do you know that yours file is crashed ?
  7. #22
    Jan 2010
    this unit is second hand
    tomorrow insert in car and post dtc from this
    airbag unit
  8. #23
    Feb 2010
    Please send me pass.Thanks
  9. #24
    Bllinda's Avatar
    May 2010
    Baltic
    Post '07 A3
    Quote Originally Posted by budG60 View Post
    I have used the file from hacper, but I am now getting the message that the control module is defective!
    Any suggestions? Other 3 faults are under investigation
    I also have 2 other modules (8P0 959 655 L and..H). Can I somehow use these modules if the ..C module is really defective?
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    008 - Implausible Signal - MIL ON
    Freeze Frame
    Fault Status: 11101000
    Fault Priority: 2
    Time Indication: 0
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    Freeze Frame
    Fault Priority: 2
    Time Indication: 0
    Does not need to change situ sensor with such errors?
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  10. #25
    Feb 2010
    have you clear dump for 8P0 959 655 C
  11. #26
    Oct 2010
    hey guys, i have the same car+module, what tools do i need to take a dump/erase the crash data?
    i have an AGV4000, KKL Interface, Elm327, VCDS and a WillemProgrammer+SPI-Flasher, soldering should be no problem, even schematics for interfaces which could help me are welcome, f.e. vag-commander schematics if it helps me to build up a tool.
    EDIT:
    we solved the problem with VCDS by just simply deleting the error, the reason why we couldnt delete it earlier was, the the unit was not built in the car (GND) and a fuse + relay was burnt
  12. #27
    Sep 2009
    portugal
    hi
    i have the same problem with this unit . car is audi a3 2007.
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Control Module Part Number: 8P0 959 655 C HW: 8P0 959 655 C
    Component and/or Version: Airbag 9.41 H13 4260
    Software Coding: 0070612
    Work Shop Code: WSC 06314 000 00000
    VCID: 428F4E3B664F
    00003 - Control Module
    014 - Defective - MIL ON
    Freeze Frame:
    Fault Status: 11101110
    Fault Priority: 1
    Fault Frequency: 8
    Mileage: 89355 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 22:34:04
    someone can help me
    many thanks
    regards
  13. #28
    Sep 2008
    Try and report
    pass pm
  14. #29
    Sep 2008
    vampirodauva your pm box is full !!!!
  15. #30
    Sep 2009
    portugal
    hi
    thanks for help
    my pm box is not already full.
    regards
