This is a present for all dk members (specially real veteran good ones, you know who you are):
Forget about installing dos or win98 in a hard disk in order to use Visa 1.83
Run Visa 1.83 from cd or pendrive!
you just need a computer with 2 real com ports and a bios capable of booting from cd or usb!
you dont even need a hard disk drive or floppy drive!
but you can install it to hard drive if you wish, by means of a script included for that aim!
MultiBoot CD or USB includes 4 versions of Visa 1.83:
VISA 1.83 Cracked English (Interface without Atmel chip)
VISA 1.83c Cracked English (Interface with K-line/COM1 Only)
VISA 1.83c Cracked English Modded (Bigger database)
VISA 1.83 English (Original Interface with Atmel chip)
warning: if visa doesn't start (because of vstart.exe issue), choose start ms-dos, then type:
call cab visa visa <enter>
dbcodici <enter>
(this starts dbcodici.exe instead of vstart.exe; vstart.exe is just a little program to start dbcodici.exe, but sometimes it fails; dbcodici.exe is the main program)
i recommend building interface without atmel nor pic chip:
http://www.digital-kaos.co.uk/forums...1&d=1276357624
edit: ALL YOU NEED http://www.digital-kaos.co.uk/forums...SCAN-VISA-1-83
more info here
http://www.digital-kaos.co.uk/forums...SB-by-manocao/
uniscan visa compilation by manocao (documents, schemes, software...)
MEGAUPLOAD - The leading online storage and file delivery service
EN version: United States keyboard and English command.com (prompts in english)
SP version: Spanish keyboard and command.com (prompts in spanish)
edit: new version 2.0
edit: new version 3.0
edit: if pendrive formatted in FAT doesn't work, format it in FAT32
note spanish version: when using format dos application, although it asks Y or N (Yes/No) for confirmation, it must be typed S or N (S?/No).
H? Manocao , i need more + engine ECU database for add
Thank you.
Hello Manocao
For sure we need this.I am clumsy in electronic and not tools for this but I decide to buy an clone Visa 1.83 from China especially I have found an old DELL Optiplex G150 with two real serial port in my closet and have refurbished it.
So I am waiting for Visa from china and for your advices.
Thanks in advance!!!!!!!!
Hi my friend.
This is a very good job. Thanks
I hope we'll be useful for all our DK mates.
Good luck
That sounds really interesting. I thought that uniscan can't work with "read only" files, how did you manage that while booting from cd? Is it working with ram-drive in memory?
exactly, ramdrive in memory!
files ready to download in 1st post!
run nero > recorder menu > burn image
if you select "track at once" and deselect "finalize cd", you will be able to burn more data sessions on the same cd later
otherwise, select "disk at once" and "finalize cd" to have a factory style cd-rom (it wont admit more data)
H? folks , help me, sorry for my question , but what?s this, the multiboot-CD to uniscan ?
What is difference with the multiboot and without multiboot to run the Uniscan ?
Thanks for All.
forgot to say:
H? folks , i am needing an softrare version Uniscan-Visa 1.8.3 C , ( C - version ) for works only 1 com port, K line , please .
Which link ?
Thanks for all.
havent you read 1st post?
183c version included in multiboot cd or usb
H? Manocao , sorry for my question , but , Uniscan visa 183 works only with the CD-boot !!!!!!!
install soft in drice C :\ is not nescessary ?
Thanks.
