Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 104
    Land of Rocks
    Default Pin code from dump Astra H CIM module
    I want to fit second hand CIM module on Astra H.
    I need pin code from dump for reset it.
    Ive read dump from 95160 eep.
    aliali18's Avatar
    tunis - (kasserine*Kairouan)
    Lightbulb
    Quote Originally Posted by tachonow View Post
    ried eeprom Dashboard 35080
    thanks digital-kaos
    Land of Rocks
    I know original code from my car but I want to fit a second hand CIM bought from shrot. I dont know from what car was taken, I have only the CIM in my hands.
    Never decoded a CIM before.
    Looking at the dump, I would try to get into the variant config with the following.
    6158
    8516
    1685
    8516
    Failing that, read the eeprom from your current CIM and post that here with your code, it may be possible to work it out.
    Login inside MCU not external eeprom
    Edit: Login inside 95160 but crypted. Will check tomorrow.
    Land of Rocks
    If I cant get the pin code I will swap the eeproms. Do you think it will work ?
    melbourne, australia
    I have swapped eeproms on these before & it works fine
    The 93c56 stores pairing info & can be read or swapped
    Can be read in circuit
    Bought a 2nd hand CIM and worked out how the codes are stored. Not sure if you still have the CIM, but here is your code.
  10. The Following User Says Thank You to pecky For This Useful Post:
    Faraday (17th January, 2014)
  11. #10
    aliali18's Avatar
    Question
    Quote Originally Posted by pecky View Post
    What is the name of this program???
    thanks digital-kaos
  12. #11
    Quote Originally Posted by aliali18 View Post
    Pecky's Vauxhall Decoder, i.e. my own software, every calc in it has been discovered by myself with tech2 and UPA USB, very painstaking work.
    I've not released it, nor is it for sale.
  13. #12
    Bllinda's Avatar
    Baltic
    Post CIM unknown
    Or I can calculate pin code from the CIM unit? Which MCU_908 send EEPROM, the black connector on the bottom, or?
    Thank you
    today
    A topic that interests me
  14. The Following User Says Thank You to Bllinda For This Useful Post:
    lequanghau (11th September, 2018)
  15. #13
    I can only calc if there is a 95160 EEPROM. My own car which has keyless entry doesn't have the eeprom. If I get time I may have a go at the MCU.
    You could post a dump and I can check if the same encoding of the security code is used
  16. #14
    Bllinda's Avatar
    Baltic
    Post
    Send hc9o8x2_2J74Y_SS damp, take a look. Pass_PM.
    Thank you
    today
  17. #15
    Quote Originally Posted by Bllinda View Post
    Thank you
    It could be hiding very well, but I can't see anything that matches how the code is stored in the 95160.
    If I get brave I will have a go on mine, but as keyless entry onces don't come up 2nd hand, it could be expensive if anything gets corrupted.
