Check first if your cable has Atmega, because we have no ideea how your cable looks like...
Hi there. Im new to this forum and need a little help. I have a VAG 12.12 cable with VID_0403 & PID_FA24. If i run a fresh install of VCDS with cable plugged in, it says valid/registered. As soon as I plug into car it goes to Unregistered.
In device manager it says Ross-tech direct USB interface and not the FFFFFFFFFF that ive read before. Im guessing the cable has been fried and was wondering the best way to go? Ive read posts before about flashing Eprom etc but cant seem to find a defined step by step method including which software to use for flashing. I am good with computers but just a little lost in the process. Thanks in advance for any help. Cheers
I am in much the same situation, My clone Atmega (sp) CPU Chinese 12.12 clone becomes unregistered when i try to connect to the car. Is it simply a case of loading this new software and the interface will update itself? Or am i missing a step?
WHY, just buy original from ross tech. #300 of the queens pound, fee updates for life with full support WHY WHY WHY.
Ah ok, so i need to find a PC with a working LPT port, I was hoping it'd flash over USB
You can do that via usb, but it is necesary avr programmer- much easy to use.
Byzan A4 (3rd January, 2017)
Hello.
Here are flash dumps for latest VAG-COM original + flash dump of China clone FW 1.96 with protection chip. All firmwares are disassembled. It's quite easy to decrypt HCC196.bin (old 512 byte bootlader) from install directory. I'm working on other tools such as FLASH and EEPROM dumper via USB, so it can be read even with fuse bits set.
BTW according to FW source code - fuse bits are not read by firmware itself, so it doesn't care if the fuse bits are set or not.
HCC196.bin is for old HW type (0x44) with PORTA.2 and PORTA.3 connected to GAL
HP196.bin is for new HW type (0x46) - not decryptable yet (no public). May be this type is used in China clone. CN Clone dump is not the same as HCC196.bin.
As I know - protection chip doesn't protect ATMega (according to schematic I don't know how it can protect it) but is used as a "key" for cracked VCDS distributed with VAG-COM. It communicates with VCDS loader through RTS/CTS pins of FTDI. If VCDS loader finds the protection chip, it then unlocks communication with ATMega, creates d1-d3 files and starts VCDS.
Flash1.92.zip
Flash1.93.zip
Flash1.94.zip
Flash1.96.zip
Flash1.96_CN_Clone.zip
basha318i (31st January, 2017), Col19 (13th November, 2019), ghicicine (28th January, 2017), hotkar (13th March, 2017), humphrey (27th November, 2018), liviudiaconu (10th February, 2017), majqt (10th April, 2020), Mrjitter (13th January, 2017), Sparky1521 (28th March, 2017), t-pirat (21st January, 2017)
I'm looking for 512 words bootloader. If someone has it please send me a private message. Maybe we can exchange some stuffs (message coding, commented firmware code, FTDI EEPROM & AVR EEPROM emulator, AVR FLASH & EEPROM dumper, ...)
Hello,friends,there is a DIY VAG 16.8.4 can help you training reprogramming,DIY vcds 16.8.4 cable with 16V8B+ 2*L9637D +ATMEGA162 +FT232RL +MCP2515 +A1050. it is support DIY any language and version by your dumps.
i have a problem with VCDS clone 17.5.0..I'm getting error -not plugged into car-.
Thx
17.5.0?
mines only updated to 17.1.1
"no plugged to the car"
- blacklisted loader and Atmega dump defective because of loader - it need reflashed and a need a new loader
- Atmega defective
-FTDI defective even its seen in the Device Manager
Good luck
Can you please tell me where I find loader and how reflashed?
