Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 40
  1. #16
    Dec 2009
    if immo car not start ford and VW not same
  2. #17
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    OK
    But can you help me to start this car???
    Is it have something with immo a alnaser(starter motor)?
    When I start the engine the starter motor is heating to much and cable from batery is heating?
  3. #18
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    Is it no one can help me?????
  4. #19
    Dec 2009
    turn ignition not start car wait 1 minets and see to LED flashing ask numder
  5. #20
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    I do that i got 3 then 2 so it is 32???
  6. #21
    Dec 2009
    send me dump from ECU
  7. #22
    DK Veteran yssf's Avatar
    Dec 2011
    somewhere
    did the car have immo light?if so,did immo light up when put ON?
  8. #23
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    Quote Originally Posted by Crash-100 View Post
    My friend can you send me a conection for
    Motorola HC11K4 84plcc
    I try to read but wont work
    Try with UPA and with Motorola cracker it want read???
  9. #24
    keygargoil's Avatar
    May 2010
    was this lost keys or have you changed the diesel pump if it is lost key post your key data it will take 2 mins to write the file then write it back and job done
  10. #25
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    Quote Originally Posted by keygargoil View Post
    Friend its lost keys
    The car is workin ok then turn off go to the shop when back no more start
    The pump is his original nothing changed.
    Tell wich dump to send from ECU or Immo Box
    From ecu I can not read i must to go to the friend to read me.
    Thank you
  11. #26
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    OK friend here is the dump from ECU
    I wait for replay.
  12. #27
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    Hey friends here is the dump
    Can you do that for me?
    I wait for replay.
    And can you explane to me when i back ecu did I have all to back to factory setings
    or have to do somethind diferent
    Or do i from the immo box remove TMS and jumper the pins 4 and 13 so I can start the car
  13. #28
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    Hello people where are you??
    I still have a problem, can someone make mi immo off with this car??
  14. #29
    Dec 2009
    immo synhro ok
  15. #30
    ubistvo's Avatar
    Sep 2009
    SERBIA Krusevac
    ok friends
    Thank you for your help
    I can not solve this car so I return to his owner
    Thank everybody for help
