Results 1 to 15 of 22
    klonone's Avatar
    Default isuzu trooper 3.0d 4jx1 DTC P1649
    hello .please i have code error P1649
    DTC P1649: Immobilizer Security Code Not Programmed
    please how to programm??
    Apr 2016
    Quote Originally Posted by klonone View Post
    Hi, I have the same problem as you, have you found a solution?
    Thank you
    Apr 2016
    Hello, I'm still looking for this solution.
    Someone would he do that
    Thank you
    klonone's Avatar
    hello, with t300 program new key and extract pin
    regards
    Apr 2016
    regards
    hello, thanks for the info.
    I will buy a T300 to try.
    regards
    Nov 2018
    Australia
    Quote Originally Posted by Odin68 View Post
    regards
    Did the T300 allow you to extract the Security PIN from your 3.0L Isuzu Trooper?
    klonone's Avatar
    Quote Originally Posted by jackaroo ted View Post
    yes, you can
    Nov 2018
    Australia
    Do you know if anyone has actually done it - extracted PIN from 3.0L Isuzu Trooper 4JX1? Because I have an MVP with unlimited tokens which is supposed to read the PIN for an OPEL TROOPER / HOLDEN JACKAROO / ISUZU TROOPER, but it doesn't work, hence why I am reluctant to buy another device if it doesn't actually work?
    klonone's Avatar
    T300 work 100%
  10. The Following User Says Thank You to klonone For This Useful Post:
    jackaroo ted (16th November, 2018)
  11. #10
    Bllinda's Avatar
    Baltic
    Here you find what you are looking for.
    today
    A topic that interests me
  12. #11
    Nov 2018
    Australia
    Quote Originally Posted by Bllinda View Post
    Unfortunately, most of those PIN cards are now well and truly lost forever. Therefore there is a need to extract the PIN from the vehicles ECU / ICU in almost every case. Then there are situations where the Immobilizer has failed completely or has self reset to 0000. I know of a vehicle with factory PIN Card 1832 - also confirmed by VIN from Holden Dealership, but I cannot program a new Key using Tech 2 nor Autokey MVP because the ICU does not accept 1832 security code.
    Hence it is vital that the T300 be able to read the existing PIN so that I can program a NEW PIN by first entering the OLD PIN to gain security access
  13. #12
    Bllinda's Avatar
    Baltic
    what kind of reason is the second picture of the uploud .... what you think
    today
  14. #13
    Nov 2018
    Australia
    Being a newbie, I'm not exactly sure what you are referring to - Sorry? But if you are referring to the picture of an Isuzu Trooper showing the location of the Immobilizer, then I already know where it is, as I have removed several of them from various Isuzu Troopers / Holden Jackaroos over the last few years, but that will not tell me the PIN code - hence the reason why I feel the need for a T300. I already have the latest version of the Autokey MVP (Token Free version) which is supposed to extract the PIN from the ECU or Immobilizer on these vehicles, but it doesn't actually do it. I have tried the Isuzu Trooper, Opel Trooper, Opel Monterey, and Holden Jackaroo from the MVP menu, but it cannot read the PIN.
  15. #14
    Apr 2016
    Hi, you can find the pin code in the case behind the glove box.
    You have to read the chip, you will have a dump of 512 KB, and open it with a program to find the code.
    I can not remember the name of the program, but if you need it I can give it to you.
  16. #15
    Bllinda's Avatar
    Baltic
    When will you be completely self-sufficient?
    and you do not belong to anything
    today
