engine code? and full foult codes
Hi All,
I have a Citroen C3 UK 57 2008 1.4 HDI non start problem. I have connected Lexia and it communicates with everything but not injection (ECU). Fault code stored in the BSI is no communication with ECU (which I imagine is the main fault). When I try to start there is nothing. Checked the transponder, all the fuses. and they are ok.
So my questions are:
Which wire is the communication from BSI to ECU?
Is the main BSI under the hood (966405580) or the one behind glove box (9659285480)?
Is this ECU a common failure? Is there any repair guides?
Thank you in advance.
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
BSI in the glovebox
BM34 under bonnet
can you com with abs and eps ?
and checked the maxi fuses under the bm34
Today is the Tomorrow you worried about yesterday ......Was it worth it ?
8HZ (DV4TD)
FAULT CODES?
gcelettronica (23rd February, 2022), sep382 (3rd August, 2019)
I've checked the maxi fuses they are fine. When I do a global test I get dialogue with ABS and EPS but when I try to go in to them I have no comms......looks like we are getting somewhere!
abs and bm34 give trouble on these link the can wires on the abs if all comes back abs is the problem.
7.31sec@203.3mph
Fault codes:
BSI
Illumination of 3rd brake lamp open circuit
No communication with engine management ecu
Instrument Panel
Remote fault
Permanent fault
Engine Speed Information
Switch module under steering wheel no comms
Multifunction Screen
Permanent Fault
Absence f +permanent on display
That's all the codes
When you say link the can wires, what do you exactly mean mate?
there are two wires goin in two coming out unplug the abs and link the twisted pairs do you have a wiring diagram.
7.31sec@203.3mph
chek power of ecu or try with another.
Yes I've got the diagram. I thought that's what you meant. I'll try in the morning and report. Thanks mate
First of all strip the covering from the wires that go to the plugs on the ECU. Find out which are the power feeds (and earths). Give the power feed wires a good pull and see if any break. The wires on these nails tend to break inside their plastic coverings just outside the ECU (usually within a few inches). Alternatively, open ECU and check power feeds at the pins on the PCB with what you should be expecting. Sounds like one 12v will be missing.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
I had this once before! Problem was BSI. I to could communicate with BSI. And all seemed to be ok! With it.
ive tapped the bsi with a hammer handle before now and everything works for a while (stuck relay ) give it a try.
7.31sec@203.3mph
Meat-Head (20th July, 2018)
