Hello
Please, can you help me with PSW file for my esl dump?
Sanks in advance
Hello
Sanks in advance
I need the password for this file. thank you so much.
Have a MB w204 where i can not turn ignition on.
I removed the electronic ignition lock and the electric steering column lock. The locking bolt for the steering column lock remained inside the ESL, otherwise it would not have been possible to remove it.
After removed ESL and EIS i connected again, and now the locking bold come out and when i put key in EIS the lock bolt go in, now i can turn on ignition and can start the car.
Next i dissambled the ESL and put grease on all parts and assembled it and all work ok, ignition goes on and car starts.
Now i dissambled it again, because i will change the motor, because black smoke near the motor and assembled it but now ESL does nothing and the ignition can not turn on.
Now maybe the nec are locked, but don`t know why, i diassembled and assembled it before many times and it worked.
So my question, can ich unlock it with @ficho software ?
Have read it, but don`t know how the procedure is for unlock, do i need only put erase in the software ?
When i install an emulator, how can i get it worked with @ficho software
Sorry for all the questions, it`s my first MB ESL
First read as ignition does not work, after that i put ELV in car and then i read it again
Can not explain it in english how i want
HI,
My software was for old esl types with Motorola inside..
this w204 esl are problematic (usually motor problem), you have to see if you have AA flag, this can happen easy.
find some friend who has such tools to help or buy some tool if you are in this stuff...
regards ficho
autodiagdoctor (4th April, 2018), chli1976 (3rd April, 2018)
when i try erase ESL (OLD type) i have error Command Execution Error.
Reading ESL - ok.
Hello guys, I need password for W203 ESL
antonypaul (22nd July, 2023), Shmortz (2nd February, 2019)
Thank you very much, I was using your program before, which is very good for that, but my laptop died ago and I don't have a key now...
post deleted
A topic that interests me
Hello guys, I need renew for W203 ESL
antonypaul (22nd July, 2023), daxxer (4th March, 2019), ficho (4th March, 2019)
