sv2hqx (14th November, 2014)
Always thought L56R .. was just a low voltage C56 .. but hey ho .. cant always be correct ..
Sorry,I just saw what I wrote,my mistake...
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
ettaoussi (7th October, 2014)
Ive done a few 8p's as well and confirm they work......
and obdsystems, just download the software, it will run so you can see what cars it covers
H.Wessel (8th October, 2014)
right here big warning to all
i purchase the clone of tm100
only after few days unit tried to do update and has now packed in
dont know why unit did this but it is now dead
the software cannot see the unit
tried re-install etc and on other computers
same problem
so to all avoid the clone and stick with fly if buying this unit
contacted seller
got told to re-install will see how this pans out
not good i think
cjawahir (7th October, 2014), gwee (7th October, 2014), obdsystems (20th May, 2015)
This is likely to happen with clone and original.
I measure the power consumption of all tools that use USB and the TM 100 uses almost 1000mAh when updating which uses the 500 mAh of BOTH the USB leads.
I use a 2100mAh power lead attached to the red plug and it works fine for updating and using generally.
cipijoint (2nd December, 2014)
many new improvements / most bugs fixed
contacted seller Nancy
seller says never had problem with there clone units
do i believe them
no
i think these are cloned or
out the back door from fly someone stealing them
gwee (8th October, 2014)
fly told me about this, out of two mcu, they cloned only one.......
they were expecting this to happan.......
return the clone tm100 and get refund
hi
Thanks for feedback,
best regards
H.W
