Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
  1. #31
    Nov 2016
    Thanks very much works
  2. #32
    bank's Avatar
    Feb 2017
    Ukraine
    wrong post was here...
  3. #33
    Top Poster incar's Avatar
    UK
    Quote Originally Posted by bank View Post
    I think, I found algo.
    Pin stores in a6-a9 and b0-b3, XORed by two different keys
    XOR for a6-a9 is 3f 46 33 d5
    XOR for b0-b3 is 46 3c d9 3f
    After XOR pin will be a7, a6, a9, a8 and the same in b1, b0, b3, b2. It's works for 16bit dumps which starts with "7F 01", "7E 01"
    The same algo and pin location for 16bit dumps which starts with "6A 0C", "6B 0C" but another keys for XOR:
    XOR for a6-a9 is 51 87 44 3C
    XOR for b0-b3 is 5A 3C 9F 35
    The same algo and pin location for 16bit dumps which starts with "04 88", "05 88" but another keys for XOR:
    XOR for a6-a9 is 8D FF 3A 3C
    XOR for b0-b3 is 3C 8E F7 C3
    I checked this algo on different dumps with khown pin and it works correctly
    Great work!!!
    I can see that your provided keys works.
    How did you worked out the keys?
  4. The Following User Says Thank You to incar For This Useful Post:
    Redas (11th April, 2019)
  5. #34
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by incar View Post
    Some dumps with known pins and known pin location, then brainstorming
  6. #35
    wembleyhill's Avatar
    Feb 2009
    Hi dont know if this will help gonna try later
    http://blog.vvdishop.com/calculate-p...-by-vvdi-prog/
  7. #36
    Bllinda's Avatar
    Baltic
    Pony-prog also reads SPI-xx160
    Quote Originally Posted by wembleyhill View Post
    http://blog.
    today
    A topic that interests me
  8. #37
    bank's Avatar
    Feb 2017
    Ukraine
    CIM for Astra H has another algo and pin location
  9. #38
    FRANCE
    When we search well we find! There is everything for it on the forum and it works very well. But you have to bother
  10. #39
    I share some info for Vectra CIM with 1J35D MCU (HC08AZ60)!
    Dumps starts with 5E DF.
    PIN location B6 B7 B8 B9 , the XOR value is: 60 35 FD 5D.
  11. The Following User Says Thank You to zottika For This Useful Post:
    nmclogandci (24th February, 2020)
  12. #40
    dragoshu's Avatar
    Aug 2016
    Dacia
    I hope this it not wrowng place to ask this info?
    I have Vectra c 2004 dusnt recognise key,Costummer buy used cim and My question it that it just 93c76 eeprom to swap from orig to donor.I attach picture with cim board.
    If I help you dont forget to push thanks button
  13. #41
    Shmortz's Avatar
    in the middle of nowhere
    you can swap if CIM is the same number, otherwise, read eeprom to see the pin and reset and reprogram all on car
  14. The Following User Says Thank You to Shmortz For This Useful Post:
    dragoshu (26th February, 2020)
  15. #42
    dragoshu's Avatar
    Aug 2016
    Dacia
    Car it 150 km far away,
    This it only solution to start this car?
    Costumer bring to me both CIM
    Quote Originally Posted by Shmortz View Post
  16. #43
    Shmortz's Avatar
    Quote Originally Posted by dragoshu View Post
    as I sad, if CIM numbers are the same there is no problem to swap!... if not you can try and report, I think 90% will work...
  17. The Following User Says Thank You to Shmortz For This Useful Post:
  18. #44
    Shmortz's Avatar
    ... but if the problem is nto im CIM himself, will not work if swap eeprom on same number CIM, are yu shure key is ok?
    try to read CIM on bench and see if it work good and can read key or not after swap eeprom
  19. The Following User Says Thank You to Shmortz For This Useful Post:
  20. #45
    dragoshu's Avatar
    Aug 2016
    Dacia
    Solved,
    I found ring damaged,replaced and ready .
