Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Default In ak500 not running smartkey.exe
    When I install software everything was work properly. After some time, I try open and write key, but not starting smartkey.exe, just in this moment I hear windows fault sound... any ideas?
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
    Jul 2013
    try to use windows XP
    Aug 2010
    Herts, UK
    yes, it is installed in xp 32bit sp3
    Aug 2010
    Herts, UK
    No ideas ?
    Aug 2008
    must be adjust com1 or com2
    this ok ?
    Top Poster raptors's Avatar
    serbia
    Contours of antivirus software re-installation AK500 and will work without problems.
    leandroks's Avatar
    Brazil
    Intall it again, but before kill the anti virus....
    Mario3's Avatar
    Dec 2014
    Hello guys
    i have the same problem cant get it to work.. I have installed it also on xp sp3 on a pc where i dont have any antivirus sw and still nothing
    has anyone a solution ?
    Mario3's Avatar
    Dec 2014
    Still have problems with smartkey.exe
    i installed it on win7 ultimate 64 bit and everything works as it should, but cant get it to work on xp sp3 32bit, installed the xp fresh and the ak500+ software when it starts doesent even search for the hardware.. but smartkey.exe when started from installatin folder works now.. The main window pops right up and only firmware update is availible. Drivers are correctly installed and in device manager is also everything ok, tried com 1, 2 and 3.. same
    can anyone help ?
    Apr 2013
    United Kingdom
    I just installed windows 7 ultimate 64bit but smartkey.exe still doesnt work. Any other suggestions?
    Hit like and thanks if I've helped you!!
    Mario3's Avatar
    Dec 2014
    I struggleed with this issue for a quite of time. Ok you can make a few things here. A forum member helped me to solve that. I had to use win xp SP2, and he sent me the software for ak500, not ak500+ !! The installation is different and when you install the ak500sw it adds some files wicj the ak500+ install didnt. So after that smartkey.exe did work and when i started ak500+ also. So it was something missing in the install that i got with my device. BUT i figure it out that i need smartkey.exe ONLY for writeing the nec in the zif socket. But what i did not try and what sure has to work also without smartkey.exe was soldering the virginised nec on the key pcb and write the key via IR port !
    So try that mate but the install of the old ak500 sw should solve your issue.
    for me the ir never worked!
    everything elsed work ok.
  13. #13
    Jul 2015
    install fresh xpsp3 black edition, apply all patches of this xp, install ak500 soft, install drivers and smartkey will work
  14. #14
    hamzadaw2000's Avatar
    Aug 2013
    i have same issue, any help please?
  15. #15
    All Ak400 and Ak500 soft work, but
    1. SmartKey program start only on IDE hdd, no any other work!
    2. have problem with comport some time not found, this come after clear driver installation
    3. for ak500 ESL 203 use any drive (local, usb) but Volume must be AK500
  16. The Following User Says Thank You to slawentiy For This Useful Post:
    hamzadaw2000 (9th October, 2016)
