Page 1 of 2 12 LastLast
Results 1 to 15 of 33
Hybrid View
    Member grizzlyt's Avatar
    Oct 2008
    Default Tutorial:back-up,restore and install E2 on a USB stick
    Because this site helped me a lot, I want you to give something back.
    This is my tutorial to back-up , restore and install your Enigma 2 USB stick on your PC.
    I hope it helps some people struggling with E2.
    As a beginner normally it's really hard, but this way it's quite easy, everyone can do it.
    You just need a free USB port, the trialware Acronis True Image and a USB stick.
    Attention: I don't take responsibility if something goes wrong, so back-up any important data before you install something on your stick, because everything will be lost.
    Formatting is not for beginners, so think twice if you are not sure about what you are doing.
    Please don't complain, threat or insult me about it, I tried to dumb it down as much as I could but there is always one possibility where everything that can go wrong will go wrong.
    P.S.: I hope you find it useful.
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
    aftermath's Avatar
    Mar 2008
    This is just a tutorial for formating a USB stick in ext2 or ext3 for IPbox, the Instalation of E2 is missing.
    but 10/10 for the effort
    Oct 2008
    Quote Originally Posted by aftermath View Post
    Well actually, if you restore a back-up to your stick you are installing the E2 system on the stick.
    That's what I meant and yes it works like the real thing.
    The good thing is that you don't need a good notion of Linux or partitioning, you just need a back-up for your box.
    Dreambox 7025-SS
    Oct 2008
    Default Enigma 1 + 2 Tools / Addons / Tuts
    SatAngels-Key-Updater for IP-Box NLB-Image
    Simple installation through the NLB-Plug-in Manager
    (Please look at the Readme in the archive)
    Then you have the plug-in
    With this plug-in you can make online keyupdates
    You can choose between this ones:
    The rb-Keyfiles from redbull301
    The IP-Box-Keybundle from minicat
    The keys are updated at the moment they are available and redbull301 and minicat are releasing them !
    Many thanks to redbull301 for this plug-in !
    We wish you lots of fun !
    Key selection:
    Dreambox 7025-SS
    Oct 2008
    Default SatAngels KeyUpdater IPBox NLB 0.0.1 b
    English v0.0.1b:
    * Bug in MiniCat's IPBox KeyBundle removed
    * Online PluginUpdate added
    further updates or bug fixes to the plugins
    can be carried out quickly online,
    without reinstall , goes a little faster .-)
    Please note readme for installation
    have fun
    Dreambox 7025-SS
    Oct 2008
    Default SatAngels-Key-Updater for IP-Box E2-Image
    English v1.2:
    following items are available:
    * Preview - preview look, from when the keys are on the server :-)
    * RB EmuPack KeyUpdate - Update the current Emu Keys
    * Individual KeyUpdates for Camd3, Evocamd, IncubusCamd, Mgcamd and SoftCam
    * MiniCat's IPBox KeyBundle
    * Online Plugin Update
    Installation:
    1. Possibility
    Copy SatAngels_IpBox_Keyupdater_E2_1.2.tar.gz to /tmp,
    log in via telnet to the box,
    change with "cd /tmp to the folder and type (without "")
    "tar -xzvf SatAngels_IpBox_Keyupdater_E2_1.2.tar.gz -C /" an press enter,
    restart your STB. With "reboot" via telnet, type 2 x "sync" before.
    2. Possibility
    Unpack SatAngels_IpBox_Keyupdater_E2_1.2.tar.gz to a local folder
    copy the folder "SA-KeyUpdater" to
    \usr\lib\enigma2\python\Plugins\Extensions
    and CHMOD all file int the folder "script" to 755.
    Restart your STB
    To use the plugin:
    Menu -> Extensions -> SatAngels-IpBox-Keyupdater 1.2
    alternatively with PKT extension:
    "red button" -> SatAngels-IpBox-Keyupdater 1.2
    with simple_emumanager:
    "blue button" -> SatAngels-IpBox-Keyupdater 1.2
    Uninstalling the plugin:
    simply delete the directory "SA-KeyUpdater" from
    \usr\lib\enigma2\python\Plugins\Extensions and
    restart your STB.
    have fun
    SatAngels Team
    SatAngels_IpBox_Keyupdater_E2_1.2.zip
    Dreambox 7025-SS
    Newbie Peter36's Avatar
    Jun 2009
    Default Internal Cardreader Driver for e2 images
    INSTALLATION
    Copy contents of archive to box.
    The CardPanel Plugin for e2 takes care of loading the driver at e2 startup.
    It also starts newcs 1.66_rc1.
    newcs.xml is located in /var/keys, a default config is provided, adapt it to your needs.
    MAKE SURE ALL FILES ARE EXECUTABLE!
    Restart e2 to load the driver and newcs.
    KNOWN BUGS
    - Removal or insertion of a card while the driver is loaded freezes the box, so don't even try it
    Have fun,
    Jun 2009
    Default Addon pre e1 HD Put
    Addon pre e1 HD
    Put this file in /tmp/ and after from panel you can install mbox and newcs
    Jun 2009
    e1 HD addons
    emus:
    mbox
    newcs
    keys-updater
    games:
    pacman
    snack
    tetris
    plugs:
    rss feeds
    weather-sky
    setting:
    setting-rotor
    aftermath's Avatar
    Mar 2008
    Default The easiest way to install/backup Enigma2 on IPbox
    All you need is Symantec Ghost and an Enigma 2 image.
    This tut works on IPbox 9000HD
    The Ghost program and the E2 image is linked at the bottom of this thread.
    the image is Enigma2_0.4.2 by Tideglo
    The image already has the satellites scanned from 45 east to 45 west and the Language is set to English.
    All you need is to replace the incubuscamd.conf with your working one and press blue button to get the cam menu to start it. And change the long and lat to yours.
    To install..
    To install E2 Ghost image using Symantec Ghost32 8.0
    put you USB stick in your PC and format it to fat32, ( i prefer to have 2 gig partitions on mine )
    you could use Paragon Partition Manager ( search this forum for it )
    open the Ghost programme, which is in the rar file below.
    then choose :-
    Local > Disk > From Image
    point to where the image is that you want to install.
    Then choose the USB stick ( usually last option )
    The operation will only take a few minutes.
    When message says done remove USB stick and put it into your IPbox 9000.
    Switch off the box.
    re boot it and press and hold the relevant remote control key to boot from USB stick,
    Thats if you have multi boot flashed on your image, if not get it here http://www.digital-kaos.co.uk/forums...-9000-a-37129/
    To back up your E2 image.
    Put your USB stick in your PC.
    Start the Ghost program then ...
    Local> Disk> To Image
    Select the usb stick and press OK (usually the last in the list)
    Select where you want to save the image to, give it a name , and end with .GHO ( example E2.0.4.0.GHO )
    A new Window will appear asking if you want to back up your image normal,fast,or high compression
    Next the message will be ':
    Image Creation Completed Successfully
    And given OK
    Now you will find the backup of your usb pen in the folder you chose earlier.
    http://rapidshare.com/files/241551894/E2_0.4.2_Ghost.rar
  11. #11
    Mar 2008
    nice post steve,good for the newbs as it can be a headache when you first get one
  12. #12
    Mar 2009
    Success first time, great tutorial.
    The image i had only came with the 2 sats pre set so i need to add a xml file the trouble is i cant seem to work out how to add it to the USB stick. Cant view the USB stick now on my Windows PC and when i mounted the stick through the NLB Webif and ftp'd to it all i could see was a Lost & Found Folder.
    How do i access the stick to add to it?
  13. #13
    aftermath's Avatar
    Mar 2008
    format it to fat 32 , in your PC.
    If windows dont auto detect it, use Paragon Partition Manager from here http://www.digital-kaos.co.uk/forums...9-0-pro-11996/
    when the program starts up, choose advanced options, then point to your USB stick and choose partition if your stick is more than 2 gig. Then once its partitioned , format the partitions to Fat32 , and give each partition a drive letter and name .
    Use the top toolbar to start each task , if its more than 1 partition to be formated it will ask to restart the PC for the 2nd drive on your USB stick.
    Once its formatted successfully , take it out, then put back in, windows should auto detect it... If it does then your ready to flash it with Ghost, if it didnt detect it, give it a few goes, same with Ghost.
    Hope that makes sense...
  14. #14
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by t.ph View Post
    Once the image has flashed properly , you wont be able to see it in windows as it will be formatted to Linux format, and wont be found with windows.
    If you only have a lost and found folder , that means you have not succesfully flashed the USB stick or it has been erased when booting up your box. Sometimes if you leave the stick in while booting to normal image it can get erased
    The image ive uploaded has a satellites.xml with all sats from 45east to 45west
  15. #15
    Mar 2009
    Dont know about the Lost & Found Folder but the image is working perfectly.
    I have downloaded the image from your link and will try that later but what i would like to know is how i can edit anything on the USB stick such as xml file and incubuscamd.conf and third party addons or are files placed on the stb?
