Results 1 to 10 of 10
    keturi's Avatar
    Oct 2010
    Lievatu
    Default Toyota Previa D4D Denso 89661-28850 need dump
    Looking for Denso 89661-28850 dump. 93C56 inside, my dump corrupted or eeprom dead, all 00 00 00...
    Would be nice to get the set with immo box tokai rika 89780-28050 93C66 dump.
    I will put keys manually then.
    Bllinda's Avatar
    May 2010
    Baltic
    Inquire. ....
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  3. The Following User Says Thank You to Bllinda For This Useful Post:
    keturi (17th October, 2014)
    keturi's Avatar
    Oct 2010
    Lievatu
    Thanks, but there is just immobox file, engine 93c56 is missing.
    Bllinda's Avatar
    May 2010
    Baltic
    write him a letter neomars pm by email
    today
  6. #5
    keturi's Avatar
    Oct 2010
    Lievatu
    still need the dump
  7. #6
    Senior Member gixxer's Avatar
    Mar 2009
    Europe
    Hello
    What the soultion?
    thx
  8. #7
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi mates. I need your help please. My problem is the info ecu eeprom was losted and car doesnt start. Can I have set files or you can fix immo syncro?
    ecu 89661-28850
    immo box 89780-28040
    key 1 - Transponder data "00 00 00 00 05 B5 34 27" / Datastream "7E 27 34 B5 05 00 00 00 00 63 63 7E"
    key 2 - Transponder data "00 00 00 00 05 A3 0C 5D" / Datastream "7E 5D 0C A3 05 00 00 00 00 25 9F 7E"
    Thanks in advance
  9. #8
    alclot's Avatar
    Sep 2009
    Melee Island
    Other question. If I make virgin ecu and immo box will I need toyota diagnostic for match immo or not?
  10. #9
    alclot's Avatar
    Sep 2009
    Melee Island
    Hi again. I find good dump from other ecu. Is it hard to find syncro between immo box and ecu?
    Thanks again.
  11. #10
    alclot's Avatar
    Sep 2009
    Melee Island
    Morning. I´m the pain on neck again.
    I was learning about this problem on forum and I finded a lot of information about immo problem in Toyota. I finded this procedure:
    The procedure is quite simple and straight forward.
    - All doors closed, driver's door open and unlocked.
    - Make sure the car battery is fully charged.
    - Bridge the pins 4-13 together with auto wire or paper clip.
    - Switch ignition to ON for 30 minutes.
    - After 30 min switch ignition to OFF.
    - Take out the bridge wire and start the car.
    - If the car starts and it still has the code B 2799, delete the code with diagnostic computer or any scan tool.
    The question is. If I will make virgin both units with this procedure the immo will be match again?
    Thanks in advance
