i try to read MB91F594B - connection like in vvdi documentation, but no success
crystal is 4mhz
i lifted up all pins and still "chip not connect"
Hi there
Is there a missing diagram on the VVDI prog?
I have done many W209 / W203 ignition which have mark on PCB ( 209 ZGW ). I find 2 types of diagram on VVDI prog. However the chip selection is wrong. 90% of those that I have done had 3L40k / 4L40K / 5L40k. The pin connections are the same but chip ID differs. Currently only show 1L59W and some other one. If you select those that are in Menu under IMMO -> BENZ then it doesn't read or reads corrupt.
GO to MCU and select the matching Mask for 4L40K and it will read using the same diagram of W209 9S12 ST12.
So please add this mask in the option when select that Immo.
Thanks alot
R7F701414 support is planned in some time or those chips work ok with other options?
complain directly to tech support via www.xhorse.pl/issue
Double post
+thanks if I helped you!
Hello Mexjack,
Did you remove components, like displayed in the cas4 V3 diagram.
Or did you cut pcb lines, like in the V4 diagram.
taxo1965 (2nd August, 2020)
mickye_dj (12th November, 2018)
carbandit (13th November, 2018), milehighlockdoc (29th November, 2018)
