Page 1 of 6 123456 LastLast
Results 1 to 15 of 85
    malczykos's Avatar
    POLAND
    Default Pin code for remote Alfa Romeo 156
    Hello.
    I need program remote for Alfa Romeo 156. Please help with PIN.
    In attachement is dump of remote receiver HC05B16.
    autochei's Avatar
    Mar 2013
    romania
    u need pin code for programing remote
    read bsi put dump here or immobox
    malczykos's Avatar
    POLAND
    Alfa 156 isn`t have BSI.
    PIN for immo box is only for transponder.
    PIN for remote coding is different to transponder and is in this dump!
    Bllinda's Avatar
    Baltic
    Look for yellow or black box .... or must be 9.1.2 or C.6.6
    And to you in a black box and inside c.5.6.x.1.6
    today
    A topic that interests me
    malczykos's Avatar
    POLAND
    Quote Originally Posted by Bllinda View Post
    For Alfa 156 it is correct remote box receiver !!! This bos is in comartment.
    Bllinda's Avatar
    Baltic
    Where is the "ring" wires to the BSI block?
    Exactly what kind of connector and the color of the wires?
    today
    malczykos's Avatar
    POLAND
    Alfa 156 don`t have BSI. Immo is in immo box under sterring whell. Remote is stored in remote receiver in compartment.
    Mar 2014
    West Sussex UK
    Remote programming pin code- 62628
  9. The Following 4 Users Say Thank You to Cromwe11 For This Useful Post:
    Cesarec (20th August, 2015), estate (7th July, 2015), instakeys (28th September, 2015), yellowstilo (24th August, 2015)
  10. #9
    malczykos's Avatar
    POLAND
    Quote Originally Posted by Cromwe11 View Post
    Big thanx.
    Code OK !!!!
  11. #10
    Mar 2014
    West Sussex UK
    If you get another one its a nice easy one. In your dump pin code is 9D9D7 xor fffff = 62628
  12. The Following 16 Users Say Thank You to Cromwe11 For This Useful Post:
    1608cc (2nd October, 2022), adamgr (8th August, 2015), Badger- (12th July, 2015), castin (7th October, 2018), Cesarec (18th August, 2015), estate (7th July, 2015), Fallen (10th November, 2015), Faraday (31st August, 2015), HeXeN (8th September, 2018), mikajna (8th August, 2015), okm (16th January, 2017), pletik (3rd September, 2015), RomanDon (6th March, 2022), Vladko (27th August, 2015), wheepy (16th November, 2022), yellowstilo (24th August, 2015)
  13. #11
    mikajna's Avatar
    Mar 2015
    Hi mate, this is pretty good info...I didnt know that remote receiver have different pin code...tell me is pin code stored on same address for Alfa Romeo receivers? or you must find out which bytes are for pin code?
    And how you'll programme remote with this pin code, with some tool or some manual way?
    Thank you in advance
  14. The Following User Says Thank You to mikajna For This Useful Post:
    doctore (5th February, 2017)
  15. #12
    Mar 2014
    West Sussex UK
    Quote Originally Posted by mikajna View Post
    For Alfa only 156 uses this type of receiver (some Fiat and Lacia models use it as well) pin code is in the same position in dump for all 156's. Programming is done diagnostically pretty much all the dedicated key programmers will do it as will AlfaOBD and plenty of other diagnostic software.
  16. The Following 2 Users Say Thank You to Cromwe11 For This Useful Post:
    Cesarec (18th August, 2015), mikajna (8th August, 2015)
  17. #13
    mikajna's Avatar
    Mar 2015
    All 156 is on same address, and what about other models are they have pin code on different address or it could be on same?
    What about Fiat Punto remote with 1 button, is this remote work on this way, or it work over body control unit, are you work on this remotes sometime?
    Here is image...
    Thanks mate, its really good stuff to know
  18. #14
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Punto is stored in BCM.
    Only 1 button reusable remote is Doblo restyling with Stilo type body.
  19. The Following User Says Thank You to simaservis1108 For This Useful Post:
    mikajna (9th August, 2015)
  20. #15
    Jun 2012
    Hi I have the same receiver box in Alfa 156, I have read HC05 from this box and by me code is 10929 (EF6D6 xor FFFFF), but when I want to program remote I can see wrong password ... Can someone help ? I attached dump file from HC05.
