A topic that interests me
I know what you write and thank you for polish translation I have only Software MES and AlfaObd. Only AlfaObd have funcion to add remote to alfa 156 without body ecu. When I connect on the Top in program is connected and pin accepted. But when i try to open storage remote, then in winndow message says not connected with pin, pin wrong.
How long i must wait to connect with correct pin?
Wysłane z mojego GT-I9100 przy użyciu Tapatalka
I got the exact same problem .... but after reading this topic many times, I understood that the PIN from recivier remote control is different from immobilizer PIN .... please correct me if I'm wrong to !
Yes You are right the PIN from remote is different
ok, thank you ... but what program you read the pin code of the remote recivier?
mikajna (27th September, 2015)
This is not easy job, you must be expert or must have some expert who can do that job...because damage which you can make while doing this job is much bigger than you can imagine, not for this receiver particular, but many module's in automotive are so expensive, and risk is huge...better find some who is master for this and bring him receiver, need to read MCU HC05
not just damage doing the job, but poor soldering like this could cause all sorts of problems and failure of the joints - I dread to think how many airbags have been reset with soldering like this.
I also noticed the new MB videos for IEA that hickleys have on their website.. shocking soldering from IEA I hope they dont do their own soldering for zed-full!!
X_PROG_M.jpgI wanted to read it with Xprog M because it has many adapters including this chip
Xprog read it but you must desolder this chip. I can't read it on board, I try and no succes.
I did not know that, I'm looking for a specialist in this case
At this week i will try again to read another hc05 with xprog and write resoults. My first eeprom is broken and i can't program new remote. Pin always is wrong. I try oryginal examiner and AlfaObd with no succes. I think someone broke it and I cant use pin from eeprom.
I read new hc05 with xprog and read new Pin. 100% succes Pin working and I store new remote. My eeprom in old box was broken so i could not program the new reamote and pin no worked.
After many phone calls, I am forced to give up trying to learn a new key on the remote control receiver.....In Romania I have not found anyone who has the necessary equipment for reading PIN code.... maybe it is, but I can not find it!!!!!
The easiest is to buy a key and a receiver from another car!
