Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
  1. #16
    Jun 2013
    Quote Originally Posted by pianoman58 View Post
    I mean't that when you use the vw tool to install a new ccm, it asks you to save the info (data) from the orig (faulty )unit, before you fit the new one, so if the data is corrupt you will put it into the new unit.
    I compared the data in my 95320 with other dumps that i had saved from other jobs and others from off here, and it all looked much the same apart from the keys etc. so i installed my new ccm with autologic but it was exactly the same.
    Over the next days with many phone calls to autologic help desk, i managed to eventually get it to work and adapt in the new esl/elv with the original keys.
    When it was finally working ok i removed the 95320 and read it and it was very nearly identical dump to what i had started with, with the orig ccm unit which i read in the first place to get the pin to adapt the new esl.
    So i decided that the failure must have been in the flash data, caused somehow by the failure of the esl.
    Looking back i'm sure that with autologic help, i could of probably done the same job to the original ccm and it would have been fixed. I couldn't write the new flash file to the orig flash chip because it was different chip in the new ccm.
    So hence my advice to others to let the dealers fit and program the new ccm without the old unit being there at all.
    This is really important info you gave out here. If you do wrong on one of these. Huge amount of money - out of the window.
    If changing just the micro switches on the steering lock could sort out the error. It would be the best way to get out of this mess. I guess it would not work each time. But worth a try.
  2. #17
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Unfortunately in my case the micro switches are not the problem. They work fine. Something else went wrong with steering lock. Switches and motor are ok but lock has lost all communication with immobiliser. That is why it went to dealer for new lock, but they could not code a new lock. I will ask on Pin code thread for Pin and see what is next.
  3. #18
    Mar 2011
    I tried adaptation using pin Whiskeyman gave me on Pin code request thread.
    Got the following;
    Controller refused the key Error 35: Invalid key
    next try
    Controller refused the key Error 12: Subfunction not supported or invalid format
    next try
    Controller refused to send a seed Error 12: Subfunction not supported or invalid format
    Tried many times. Always get one of the above errors.
    anyone got any ideas?
  4. #19
    DK Veteran JIMMYQ's Avatar
    Mar 2008
    put another comfort control module in that will be your problem
  5. The Following User Says Thank You to JIMMYQ For This Useful Post:
    Diagnosticated (4th September, 2015)
  6. #20
    ohkarol's Avatar
    Oct 2010
    PL/UK
    CCM module can be updated by ODIS-E . Updating module could solve some problems with steering lock.
  7. The Following 3 Users Say Thank You to ohkarol For This Useful Post:
    Diagnosticated (4th September, 2015), HeXeN (11th October, 2015), yugo45 (22nd February, 2017)
  8. #21
    Mar 2011
    Quote Originally Posted by JIMMYQ View Post
    Do you know if it is possible to fit used ccm? Some people say yes, some say no.
  9. #22
    mislav88's Avatar
    Mar 2011
    yes it is possible, a changed few of them with the same p/n, just swapped eeprom and worked fine. in all i had 00003 defective dtc, probably flash corrupted...
  10. The Following 4 Users Say Thank You to mislav88 For This Useful Post:
    bonux (30th June, 2017), Diagnosticated (6th September, 2015), Elektrik001 (19th September, 2019), HeXeN (11th October, 2015)
  11. #23
    Mar 2011
    Quote Originally Posted by mislav88 View Post
    Thank you mislav I am waiting for a used ccm with same part number to arrive. I will swap eeprom as you say and see what happens.
  12. #24
    Mar 2011
    Update: Swapped eeprom 95320 into used CCM with same part number. No luck. Fault exactly the same, car start still blocked by immobilser. Any suggestions welcome.
    Yes I have already thought of setting it on fire.
  13. #25
    west mids, uk
    full set from scrap yard??
    if you do this, then read all modules data and write to old units, just to see if it will work.
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  14. The Following User Says Thank You to ninja123 For This Useful Post:
    Diagnosticated (9th September, 2015)
  15. #26
    Mar 2011
    Quote Originally Posted by ninja123 View Post
    ninja
    Thanks ninja that may have to be my next step. This car is driving me mad.
  16. #27
    May 2013
    swapping the eeprom from a unit with 00003 defective fault code on to another second hand unit fixed the problem OK?
    I have a passat here that was bringing up a steering lock fault etc, fitted and coded a new steering lock but the car has come back with the same problems.
    I'm now thinking its a fault with the CCM and was wondering if just swapping the eeprom to a second hand unit will sort it or if the fault lies in the eeprom being corrupt?
    Sorry to jump on this thread!
  17. #28
    ohkarol's Avatar
    Oct 2010
    PL/UK
    swap eeprom to new module or update flash on the old one
    it't the flash corrupt problem
  18. #29
    WW
  19. The Following 11 Users Say Thank You to elephantul For This Useful Post:
    abdonete (5th June, 2020), arti1 (27th July, 2019), damih (7th September, 2016), Elektrik001 (18th September, 2019), gogoli (15th November, 2020), HeXeN (11th October, 2015), jmac200t (29th August, 2019), joze (8th October, 2019), mcgywer (29th May, 2017), Saulius Saulius (28th September, 2015), yarecky3 (12th March, 2017)
  20. #30
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Have same problem, don't accepting pin with new lock, always fault "incorrect key" . Will see tomorrow I will test this solution.
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
