Results 1 to 15 of 25
    Newbie Linden07's Avatar
    Aug 2016
    Default change odo on BMW X6 with DigiProg 3 v. 4.94
    Hi everyone,
    i want to change the clock on a bmw x6 year 2009 and i have the digiprog 3. Now, i've been reading that it could be dificult. Anyone can tell me how to do it? can it be done via odb2?
    Aug 2012
    outerspace
    Dash out remove chip new chip and cas needs doing only orig digiprog will do cas
    Jan 2016
    Central America
    And if you have clone use r260 cas programer. Works fine, never had an issue
    work via obd conector
    Only on some will cas go obd be prepared to remove
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    DOING CAS BY OBD IS NOT THE BEST WAY, USE ROSFAR SOLDER NO ISSUES DONE TONS
    Reading is fundamental, asking is easy............................
  7. The Following User Says Thank You to XmoDDeR For This Useful Post:
    sagie1zn (27th May, 2017)
    Aug 2016
    i?m a bit confused. some of you say that it works fine, others don?t.
    Maybe it?s important to say that i have the digiprog 3 from china, not the original one. I understand that it works fine with Rosfar or other tools, but i only have the digiprog. Has anyone tried with the digiprog 3 from china and succeed?
    Thanks...
    In any case you need to open dash and remove eeprom or erase it with special programmer. This is not an OBD only job!
    1) Do you have new m35080 eeprom so you can replace it?
    yes? -> try it
    no? -> 2)
    2) Do you have a tool to erase the m35080 eeprom?
    yes? -> try it
    no? -> let somebody with experience do the job.
  10. The Following 3 Users Say Thank You to exe123 For This Useful Post:
    doctore (24th January, 2017), jomberykaso (29th May, 2017), maremuruk (29th May, 2017)
  11. #9
    brend's Avatar
    Oct 2015
    Same where
    9s12x Gold Programmer works cas 3 good to for cas,never had and issue to.What ebaut dash your dash have 080D0WQ EEP.,so you need eraiser programmer for this or new 080D0WQ EEP. or 35080 eep.
  12. #10
    Mar 2011
    Sabac , Serbia
    r270 works fine and erese dash eeprom
  13. The Following User Says Thank You to ceni75 For This Useful Post:
  14. #11
    May 2015
    FRANCE
    dont play with this if you havent tool....remove dash and cas and get somebody who have right tool 30 min job.
  15. #12
    Mar 2013
    make cas3 with digiprog 3 over obd no problem, and dash take out and make by xprog m or r270
  16. The Following 2 Users Say Thank You to electronicservicemate For This Useful Post:
    doctore (24th January, 2017), doslamer (28th January, 2017)
  17. #13
    Usualy I remove both and do with r270. Never have problem.
  18. #14
    Apr 2016
    Friendly advice, don't do CAS via obd with china tools... You will never know what could happen. Especially with tools that don't have option to read and save...
  19. The Following User Says Thank You to alkaskad For This Useful Post:
  20. #15
    Mar 2017
    Colombia
    Watching this thread. I'm interested since today I got a car today but it's 2016 model One of them is how is your process of modifying that car your mileage.
    I read other threads and this car looks FEM
    BMW X6 2016
    WINNER THE LOSER
