Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    Jun 2016
    now I read MC9S12DG128 - 3L40K with carprog without problem.
    CARPROG:
    In carprog i am using A10 cable.
    Red --> 77 VDDx
    Brown --> 76 VSSX
    Blue --> 30 Reset
    Gray --> 15 MODC
    Just select MCU and read.
    Maybe it will help someone in future
  2. The Following 6 Users Say Thank You to Nezakabude For This Useful Post:
    ecufix (17th May, 2022), Kayhan 17# (26th November, 2020), mkopytekchi89 (30th August, 2019), Rick3000 (7th May, 2019), turbo16v (19th May, 2021), urcarpc (4th October, 2020)
  3. #17
    Haveing the same trouble with Xprog Org. 5.84 at the moment.
    It Checks, then "bypass security" and then "device is silent"
    I tryed with orignal scematic , 2 different ones from Forum,
    with and without Pins lifted, with 4,5,6, and 7 wires connected.
    Maybe i should get me a Carprog....
  4. #18
    Nov 2017
    Hi all. I have the same problem.
    I want to read Motorola MC33690DW CIM
    Can I read with CarProg or Upa?
  5. #19
    May 2018
    Has anyone managed to read this processor with the Upa programmer?
  6. #20
    Aug 2018
    East Pole
    Works with upa 1.3 with nec/motorola 912 adapter. The bad news are that i cannot pass the security issue and bypass it... so, xprog or orange 5 or mc912 programmer is the alternative
  7. #21
    Member turbo16v's Avatar
    Mar 2018
    Default impossible to read
    Hello!
    I'm also trying to read a mc9s12dg128cfue with xprog 6.12 and orange 5. but get different dumps and none is correct.
    the MCU is desoldered. I don't get any communication with Carprog 10.93 and upa.
    i already have problems with spelling in my mother tongue and google translator is not doing better
  8. #22
    fuzz1's Avatar
    Jul 2019
    How does xprog read the secure mcu? Will UPA read it if you get the security code?
  9. #23
    May 2020
    [QUOTE = fuzz1; 4143553] Hola
    ¿Cómo lee xprog el mcu seguro? ¿Lo leerá UPA si obtiene el código de seguridad? [/ QUOTE]
    hi MC9S12DG128
    to read in circuit con upa you must lift the reset leg
  10. #24
    rafal's Avatar
    UK - PL
    Quote Originally Posted by wellson View Post
    hi MC9S12DG128
    not true...................... xprog is reading without any lift pins
    need help
    now my goal is to buy xp-005
    who will help?
  11. #25
    fuzz1's Avatar
    Jul 2019
    What about reading with UPA with security bytes known? Would that be possible? Anyone tried and was successful?
    I'm curious to know how xprog goes about reading secured chips without inputting security bytes.
  12. #26
    -HC05, HC08, HC12 each is with completely different securing architecture.
