yugo45 (13th November, 2016)
ok do i need pin to program key
Use vag k+can commander and done without pin.
Best regards.
Dragon
could i get pin from dash please 912d60 thanks
Dumps open fine.
3 keys registered
Does not come up with PIN in this case.
If you find someone in your area. They could add it for you.
Or maybe check out.
Vag_Tac_o?
A topic that interests me
Hello.
yes the pin which bllinda share it here 09335 is the correct pin.
Using other tool
Yes pin is 9335
