Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Junior Member Ukhammy2015's Avatar
    Sep 2015
    Default vu solo 2 multi sat problem
    Hi all
    i have set up my box with 28 d astra on one satteliter no problem fine now i want to set up my other dish motorised.
    what will i need to do to set up all the other sattelites and how do you switch from lnb 1 motorised to lnb 2 fixed astra?
    Vu solo 2. , motorised 1 metre dish
    digicon's Avatar
    Jul 2009
    you dont need to do anything setup the other tuner as Simple - Positioner and then enter your longitude and latitude details if your Motorised dish has been set up with USALS anyway.
    After that just install a Motorised channel list
  3. The Following User Says Thank You to digicon For This Useful Post:
    Ukhammy2015 (15th December, 2016)
    Sep 2015
    Is this list the catseye list and where does that go onto thebmemory stick or a dir on receiver if so what directory please
    Sep 2015
    Ok because i am new i wanted to make it clear what i am asking
    Vu solo 2 set up with tuner B set to a fixed dish on 28 with the q skin all working fine
    i now want to set up my motorised dish to tuner a and this is what i am stuck on.
    i have downloaded a list called cateye which has all the satellites on
    Waht i require help on is
    a how to set up tuner 1 for motorised on my solo 2 ? are there any guides for this ?
    the cateye file where do i copy this too is it the memory-stick or the main directory on the vu solo if so can someone tell me what directory please
    the prgogram i am using to transfer my files to solo is the dcc dreambox control centre
    thanks in advance
  6. #5
    digicon's Avatar
    Jul 2009
    This well written guide for your channel list: http://www.digital-kaos.co.uk/forums...t=dreamboxedit
  7. The Following User Says Thank You to digicon For This Useful Post:
  8. #6
    P&D's Avatar
    May 2010
    To setup tuner 2 for the motor dish
    Goto www.dishpointer.com
    enter your postcode........and get the Long & Lat (see photo bottom left)
    press menu on the remote setup/service searching/tuner config/tuner B/press sideways on the remote till you get simple
    then enter the Long & Lat east or west
    Then go to BBC1 on your channel list (28.2) the dish will move
    if your dish is setup right you should get a picture
  9. The Following User Says Thank You to P&D For This Useful Post:
  10. #7
    Sep 2015
    Thanks p&d
    i may be getting confused here tuner b is up and running as a fixed sat fir astra 28
    what i cant do is set the postioner up fir the mutl sat option on tuner a
  11. #8
    P&D's Avatar
    May 2010
    the same as above but use tuner A instead of B
  12. The Following User Says Thank You to P&D For This Useful Post:
  13. #9
    Sep 2015
    this is my current set up
    also where do i put my cateye files directory unsure and do these go on memorystick or dir of solo when i ftp
  14. #10
    P&D's Avatar
    May 2010
    Digicon gave you a link how to install a channel list did you read it ?
    middle photo of the 3 once on that screen input the Long & Lat
  15. The Following 2 Users Say Thank You to P&D For This Useful Post:
    digicon (15th December, 2016), Ukhammy2015 (15th December, 2016)
  16. #11
    P&D's Avatar
    May 2010
    You said one of the tuners are set up for 28.2 so what channel list do you have on the box ?
  17. The Following User Says Thank You to P&D For This Useful Post:
  18. #12
    Sep 2015
    I only have one channel lust at monent 28 east
    I did look at the link digicon recomended but this realted to a drambox and also channels on 28 e and i have them
    am i right or wrong with my thinking p&d
  19. #13
    P&D's Avatar
    May 2010
    Vu Solo & Dreambox both use the same channel list
    download this....http://www.digital-kaos.co.uk/forums...=1#post2886827
    the attachment i have put in this post at the bottom......use this to upload the channel list
    unpack it/run it
    enter the box IP address name password
    then connect and upload the channel list
  20. The Following 2 Users Say Thank You to P&D For This Useful Post:
    digicon (15th December, 2016), Ukhammy2015 (16th December, 2016)
  21. #14
    Sep 2015
    ok thanks p&d and digicon i have done as explained so i will now have the sats bouquet on my receiver
  22. #15
    Sep 2015
    thanks to all who have helped me a week ago i had never used a linux receiver and with your help it is up and running cheers great group
  23. The Following 2 Users Say Thank You to Ukhammy2015 For This Useful Post:
    digicon (18th December, 2016), P&D (18th December, 2016)
