Results 1 to 5 of 5
    Oct 2010
    EU
    Default Mercedes Truck - TEMIC ecu - injector 4,5,6 error
    Hello all,
    who can help with any suggestion, how to solve this error:
    the engine was not running, the driver for injectors 4,5,6 was broken, i have change it
    now the engine runs, but there are another fault codes for injectors 4,5,6 ... fault codes 15326,15426,15526
    All drivers are OK. Have anybody any idea, what can i do?
    Many thanks in advance.
    Did u put original value transistor??
  3. The Following User Says Thank You to yokazik For This Useful Post:
    Pali33 (13th February, 2017)
    Bllinda's Avatar
    Baltic
    This may be sup-sub 50 more ....
    Quote Originally Posted by johnythefox View Post
    yes,you can,but the 40n06 need to be logic level mosfets
    today
    A topic that interests me
  5. The Following User Says Thank You to Bllinda For This Useful Post:
    Pali33 (15th February, 2017)
  6. #4
    Feb 2014
    jordan amman
    hello
    test fuose resister and bank 1 transistor or bank 2
    Apr 2019
    I have the same problem here.
    Have changed 40n60, also all 25n60 on bank2. The same errors.
    I have tested all mos on board, diodes, resistors, aluminium caps... Everything seem fine.
    Any ideas will be much appreciated.
